Metallic rattling noise under acceleration
Hi all, getting a metallic rattling coming from the rear end when I accelerate. Its worse when i get on the gas in a lower RPM. I poked around looking at the driveshaft and its got some play in it. Video included below. I can also push up on the front U-joint and it has a slight amount of give. Is that amount of play normal??
http://personal.utulsa.edu/~nathan-b.../3propelle.pdf
page: PR-8, 0.05mm (0.0020inch)
eg, No that is likely abnormal play. Your noise could be coming from the catalytic converter heat shield also.
