Sponsored by: CARiD
2 cooling fans??? one is on one isnt??
Old Feb 4, 2013 | 01:32 PM
tattuJay's Avatar
Smile 2 cooling fans??? one is on one isnt??
Ive been reading posts since I bought my 93 runner about 4 months ago. when I bought it the air hose that connects to the throttle body was split and it wouldnt idle, it would just cut off if you took your foot off the gas. Replaced it with an after market hose. since then it idles but its never been steady. usually starting cold its around 1800rpms. then it can go anywhere from 1200-2000rpms after its warm. it will stay steady for awhile but eventually it will jump or drop. Anyway, last week end I went on a camping trip to the mountains. After about two hours of highway driving we got to the mountain and pulled off to make a drink . I left the truck running for about 20 mins. It was around 10 degress outside. It just cut off, wasnt really paying attention so not sure what happened, just know it cut off. I had to jump it to get it to start. Thought it was battery or alternator or something. Drove it to where we were gonna make camp, about a 1/2 mile of snow covered rough terrain, large rocks, steep hills etc. No problem. Once at camp, while unloading, I left the truck running to charge the battery just incase that was the issue (i understand the battery dying while it was running wouldnt normally cause it to shut off). I let it run for about 30-40 mins, it over heated and blew a hose where it attatches to the heater core switch(not sure of the proper term there, the part thats attatched to the firewall that opens and closes to allow water to the heater core). Had a piece of hose and while replacing noticed that where the hoses on either side of that heater core switch attach to it, the male sleeves on the switch were both cracked. So i bypassed the switch. topped the coolant off. Drove for about 20 minutes and lost my heat. Parked it for the weekend . Towed it home. Replaced thermostat with OE. flushed radiator, refilled, burped the best i could. Drove about 20 mins with heat working then i felt the heat temp drop enough to notice. Then it went back to normal. Then drop again, then back to normal. It seemed to raise (the heat temp from the vents) whenever I was on the gas then drop when I let off, but not every time. Temp gauge raised slightly a couple times but just a little, stayed close to the middle. After an hour and a half of driving I lost heat completely and temp gauge went to the red. Pulled over immediatley. I was close to the house by then so let it cool and when I started it, it would not idle. Had to keep foot on gas....babied it to the house. Let it sit over night. Started it next morning, idled at 2000 rpms. dropped to 1500 rpms after warm. heat was working but not nearly as hot as usual. drove about 20 mins and lost heat again, temp went to the beggining of red zone, just barely and then fluctuated slightly cooler and then back to barely redzone. Drove it home (about 10 minutes, through a couple lights and sitting still didnt change much except it didnt fluctuate to a little below redzone as it did while driving. As i was pulling in the drive way i lost idle again. I let the engine cool and it started same as it had after letting it sit over night, 2000rpms at idle then around 1500 after warm. Let it idle about 30 mins, temp gauge stayed dead center. Havent drove it again. I did notice that the fan on the moter side was blowing but the small fan on the bumper side of the radiator started blowing when I started it up but immediatley cut off and never blew again. Any idea whats going on? Before replacing thermostat I did compression check on radiator and cylinders, all good.
Old Feb 4, 2013 | 01:50 PM
tattuJay's Avatar
Sorry so long guys!!!! please help!!!
Didnt intend it to be so long but figured Id lay it all out there since I have seen the questions being fired after someone posts a question about a mechanical issue. Thought Id give all the pertinent information I could think of up front. Hope someone can give me some guidance on this, thanks in advance.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
128keaton
Sep 3, 2015 05:09 PM
