Sponsored by: CARiD
1985 22r no compression
Old Jan 26, 2013 | 03:31 PM
russ70's Avatar
I have a 1985 22r and i i had to chang head gasket in it. I pulle the head and pulled the cam out of the head but whe i went to reinstall the cam in the head the previous owner had over tightend the cam bolts an stripped the treads. I took the head to the machine shop the put helicoils in all 6 bolt holes and they resurfaced the head for me. I put the head back on with a new fell-pro head gasket reset timing and now i have no compression but on the #1 cylinder and i have also put oil in each cylinder to check the rings the #1 cylinder the gauge hits 180 but does not hold the pressure the rest of the cylinders the gauge does not move. I am at a lose as to what do next any help would be greatly appreciated.
Old Jan 26, 2013 | 04:46 PM
85celicagthatchback's Avatar
Check your valve lash. After u install a new head gaskit u must re torque the head after u get it warmed up the first time. Then u must reset the valve lash!!!!!! If not and the valves tighten up u will not build compression.due to the valves sticking open then ull burn a valve l. Reset the valves to .007 intake and .009 exhaust with engine warmed up of cooled .006 intake and .008 exhaust
Old Jan 26, 2013 | 06:24 PM
russ70's Avatar
i dint think to check the valve lash will do first thing the mourning
Old Jan 27, 2013 | 09:25 PM
Happens to the best of us. Let me know what u find
Old Jan 30, 2013 | 02:56 PM
russ70's Avatar
Hey thatnks for the help that was the problem got it runnin like a raped ape now thanks again
Old Jan 31, 2013 | 09:17 AM
what did u set the lash to?hope u didnt burn a valve
Old Jan 31, 2013 | 09:34 AM
russ70's Avatar
i=.007 amd E=.009 when warmed up
Old Jan 31, 2013 | 11:53 AM
ok did u retorque the head like i said ?just checking the final torque on the head bolts
Old Jan 31, 2013 | 11:54 AM
russ70's Avatar
yeahs have it torqued at 63ftlbs
Old Jan 31, 2013 | 01:33 PM
should only be 58 but 63 is ok cuz thats a 20r head bolt torque
I8URSVT
Oct 5, 2015 05:42 PM
Yont283
Sep 20, 2015 10:56 PM
Gurr
Sep 12, 2015 09:51 PM
Yont283
Sep 12, 2015 10:03 AM
ac7822
Sep 11, 2015 08:49 AM
