Sponsored by: CARiD
1985 Trans Problems
Old Jan 2, 2016 | 02:41 PM
SAyota's Avatar
1985 Trans Problems
Today I bought a 85 4x4 pickup for $1000. It was a pretty good deal but something is up with the transmission. It will not got into 4th gear while moving. I'm assuming the synchro is bad and I should just get another transmission but is there anything I can do to avoid this? I was going to buy a shifter bushing from Marlin Crawler hoping it would fix the problem. Any suggestions?
Old Jan 30, 2016 | 08:28 PM
moroza's Avatar
Do any other gears have problems? Does it go into fourth with the engine off and the truck stopped? If the engine is running with the clutch out and the trans in neutral, and you clutch in and immediately try to put it into fourth, does it go? The answers will determine what is likely the problem.
Old Jan 30, 2016 | 08:30 PM
SAyota's Avatar
Thanks for the reply. I ended up getting another tranmission.
Old Jan 30, 2016 | 08:37 PM
moroza's Avatar
Ok, cool. I was on one of my "let's see which Newbie Tech threads are being neglected" kicks.
jkj2000
May 17, 2016 11:36 AM
JP Purdom
Dec 19, 2015 03:56 PM
99SC4Runner
Nov 25, 2015 06:26 PM
seacoats
Nov 15, 2015 11:38 AM
jhsantacruz63
Oct 22, 2015 01:03 PM
