Sponsored by: CARiD
Interference or not?
Old Mar 2, 2016 | 07:38 PM
gjewers's Avatar
Just about to purchase an '01 Highlander with a 6 cylinder. I've heard two stories that is IS and it IS NOT an interference engine. Anybody able to clear this up for good?
Thanks.
Old Mar 10, 2016 | 10:23 AM
se7enine's Avatar
VVTi is interference
Old Mar 10, 2016 | 03:36 PM
MudHippy's Avatar
Can you substantiate that claim in any way?
It seems a lot of trouble to go to by cutting reliefs for the valves in the pistons. If the valves can hit them anyway.
And what definition of interference are we talking about? Like if the timing belt/chain snaps you're screwed? Or if the VVTi system fails(mechanical failure, ECU failure, causing the the high rpm lobes to be used at low rpm)? Or would both have to happen? Seems like both is more likely. Or maybe a more suitable semi-interference designation is needed...possibly. Maybe there already is such a thing...
Old Mar 10, 2016 | 06:59 PM
se7enine's Avatar
https://en.wikipedia.org/wiki/Toyota_MZ_engine
They feature cast aluminium pistons with an anti-friction resin coating (moly) and valve depressions that decrease the chance of valve-to-piston interference in case of timing belt failure on motors without VVT-i. They also use steel rings, smaller-diameter shot-peened rods, and a forged steel crankshaft.
Tennesseestorm
Feb 8, 2016 01:45 PM
gjewers
Feb 5, 2016 07:55 AM
gjewers
Feb 4, 2016 05:44 PM
Msukefo
Jan 7, 2016 08:38 AM
KiloAlpha
Jan 4, 2016 07:13 PM
