Sponsored by: CARiD
Cinder Block
Old Nov 12, 2015 | 06:04 PM
Elow007's Avatar
Cinder Block
Just curious if it is OK to put the rear axle on cinder blocks. I want to remove both tires to take them into the shop and would like to just put the axel up on cinder blocks overnight. Bad news, or go for it?
Old Nov 12, 2015 | 06:10 PM
Terrys87's Avatar
I have to admit I have done it in the past but would not recommend it. Blocks do crack and break. For an overnight thing you could probably get away with it but don't make a habit of it.
Old Nov 12, 2015 | 06:38 PM
Elow007's Avatar
I have jack stands, but the truck sits at a slight incline in a gravel driveway so I thought cinder blocks on their sides with the holes facing the sky might provide more strength and a bit of a buffer if the truck decides to "shift".
I was mostly curious if the rear axle could be damaged in any way from leaving that much weight on an inboard point. Thanks for the reply.
Old Nov 12, 2015 | 07:30 PM
dropzone's Avatar
Fossilized
i have had the 8x8x16" cinder blocks crumble. Jack Stands
The axle should be fine for a limited time
Old Nov 12, 2015 | 11:27 PM
wyoming9's Avatar
Red face
About the only place cinder blocks should be is in the bed!!!
They do strange things for no real reason.
You could come out in the morning to find one has just collapsed would that be enough to roll your truck over??
Bottom line it is your truck !!
Old Nov 13, 2015 | 02:13 PM
Elow007's Avatar
OK, no cinder blocks then, thanks for the good advise.
Boomer8404
May 31, 2016 11:29 AM
1uzRunner
Mar 31, 2016 07:53 AM
Matt93eg
9
Nov 18, 2015 04:55 PM
mj928
Nov 7, 2015 10:45 PM
Rob2thec
Nov 7, 2015 08:11 AM
