Sponsored by: CARiD
3V-ZE Power Help
Old Nov 22, 2015 | 09:15 PM
RoninX's Avatar
3V-ZE Power Help
So i have a 1990 Toyota 4runner V6 4X4 I bought id say probably 4 months ago, and i just recently started to really take it off-roading and such.. but i was wondering what sort of things i can do to really bump up my power, even if its just a little. Going up hills for some reason or going through deep puddles feels like its putting a major strain on my 4runner, its like it doesnt even want to move, and sometimes it doesnt. Any ideas?
172k miles
automatic tranny
Old Jan 16, 2016 | 03:21 PM
Jrose's Avatar
Well one thing I know that works decently well is advancing the timing to 12. I did that and I have a bit more power and a touch better fuel economy. Other than that the 3.0 is called the 3 slow for a reason.
Old Jan 16, 2016 | 05:42 PM
RoninX's Avatar
I don't mind that it's slow, it's just the power, it barely can go up a hill.
Old Jan 16, 2016 | 08:42 PM
Jrose's Avatar
Like I said advance the timing a bit.you could also check things like your air filter, sparks plugs, clean your throttle body, you know tune up stuff.
Old Jan 16, 2016 | 11:13 PM
dropzone's Avatar
Fossilized
The 3.0 likes to blow headgaskets around 160k
Might wanna do a compression test.
This motor wasn't one of toyotas better ideas, hence why it was only used for 7 production years
Old Jan 17, 2016 | 01:33 AM
RoninX's Avatar
I think it may be fuel related or tranny related.
Old Jan 17, 2016 | 01:15 PM
Jrose's Avatar
I know some people don't like doing this but occasionally I run sea foam through my vacuum lines and put some in my gas tank to keep everything a little cleaner and I notice my engine does run better after. I have the 3.0 to.
Old Jan 18, 2016 | 04:55 PM
Punchy's Avatar
What tire size you running?
What is the axle gear ratio you running?
Old Jan 19, 2016 | 11:06 AM
Jrose's Avatar
something i have been doing a lot of reading on is the isr mod. It looks basic enough and it gives a chunk power but opens the possibility of hydrolocking a bit. just avoid deep water.
Old Jan 19, 2016 | 11:57 AM
88toyotaOleMiss's Avatar
Don't use SeaFoam. Use Gumout
Old Jan 19, 2016 | 11:59 AM
Cut out your catalytic converter. Your truck is going to be a little louder and will smell like white trash, but you'll free up a little more power because there's less restrictions.
coryc85
Dec 5, 2015 08:42 AM
davidsalas
Oct 17, 2015 11:27 AM
128keaton
Oct 4, 2015 05:36 PM
meatballs
Sep 16, 2015 06:25 PM
AlexJet
Sep 14, 2015 09:00 AM
