Sponsored by: CARiD
22r-e clutch hydraulics
Old Nov 9, 2015 | 07:21 AM
Jjennings5.9's Avatar
Just a quick question on the hydros, am I being paranoid or will I be fine with off brand slave cylinder and master cylinder?
Also best way to bleed the clutch system?
Old Nov 9, 2015 | 07:27 AM
Terrys87's Avatar
It is a 50/50 chance. Plenty of threads on here about faulty parts. You can get OEM online in several places for about the same price.
I manually bleed mine by pumping the clutch and then opening the bleeder valve. If you have one of the tools that just one person operates it would be nice but I have to use two people to bleed mine.
Old Nov 9, 2015 | 07:31 AM
It's lifetime warranty either way, its just more convenient to go down the road to the part store I guess, I'm needing it today, just gonna try my luck I believe. Thanks for the info!
Old Nov 9, 2015 | 07:53 AM
paynemw's Avatar
bro... buy aisin... i just bought a aisin clutch master cylinder for $25 shipped off amazon and I bought the slave cylinder for like $17 but I will replace it with an aisin soon. I bench bled both of them and the system is fine. aisin is the only way to go
Old Nov 10, 2015 | 08:08 AM
wyoming9's Avatar
Red face
You will get real good at changing them out
Old Nov 10, 2015 | 10:31 AM
mwisham's Avatar
I got a master and slave from O'Reilley's and have not had a bit of problems. Just bleed it out properly and you should be fine. Bleed it just like you would brakes. Bench bleed before installation then have someone pump the pedal and break the bleeder on slave loose. Do this until all old fluid and air are purged.
henryj
Nov 1, 2016 05:30 AM
wiseguymmiv
Nov 13, 2015 12:08 AM
Tachanka
Nov 9, 2015 12:18 PM
AppalachianOffRoader
Nov 8, 2015 07:32 AM
Shouldbhuntin
Nov 6, 2015 05:01 AM
