Sponsored by: CARiD
The new silent motor
Old Dec 7, 2015 | 06:08 PM
thefishguy77's Avatar
Went to go for a drive this evening and my engine decided it was going to go in to silent mode. Not very awesome. Got to ride in a tow truck. Not very awesome
But got this cool pic
It sounded like I spun a bearing. But with out the howl. I am going to strip the used short block I have in my garage tomorrow an try and get it to the machine shop tomorrow or Wednesday. If I could get this put back together by the end of next weekend it will be a miracle.
We shall see. Wish me luck. I already have an engnbldr head & cam. Time to order the timing chain and rebuilt kit as soon as I know the bore size needed if it needs to be bored out.
Details. 85 sr5 4runner 5 sp. 233,000 miles all stock
Old Dec 8, 2015 | 08:55 AM
Update. I think I have located a very low millage 22re. 120,000. I that is running in a totaled truck currently. I believe I can pick it up for around 300. If I get lucky and the compression is good I am going to grab it do a head gasket so I can put my new engnbldr hea and cam on it. Swap flywheels and put my new 1200# marlin crawler clutch in it. I guess my only question is do I just put a steal backed timing chain guide on and run the Toyota chain and sprocket/tensioner or just swap the whole new set over. It's DNJ but Toyota stuff is hard to beat. What are your thoughts?
Old Dec 12, 2015 | 12:28 PM
Update number 2:
The low mile 22re fell through. Then another turned up. And the more I think about using someone else's rebuild the more I talked myself in to tearing my other long block which I presumed was in much worse shape than it was. After I pulled the head I found the cylinder walls to be scratch free and clean. Also the crank bearings look goo but rod bearing are showing signs of age. I plan on just replacing all crank and rod bearings. I plan on getting the block decked just enough to get me a good non pitted surface. And then barring any new surprises when I pull the crank out. I am going to just hone the cylinders erring the pistons and put it back together. Rear main seal will be replaced as well.
Am I being stupid. I normally would have it taken out to the next size up piston and replace everything by money is very tight right now. Any input/feedback is appreciated.
I will upload pictures of my torn down block tonight or tomorrow morning and tomorrow I am working on a buddies fj80 and pulling the injection and exhaust off my runner motor so it's easy and ready to pull. Will take pictures of all the fun
Obmi
Jan 4, 2016 06:22 PM
Corvoid
Dec 11, 2015 11:21 AM
Whitemoneypit
20
Nov 1, 2015 10:20 AM
FRANCOARMANI
Oct 19, 2015 07:33 AM
alexcarey
Oct 4, 2015 09:56 AM
