Sponsored by: CARiD
90 yota
Old Jan 25, 2016 | 07:22 PM
K.P.YOTA's Avatar
90 yota
Let me start by saying I'm new to forums so if I do something wrong SORRY.
I have owned and repaired 22re s for years but I'm at my WITS end with this one.
HERE WE GO.
I've got a 1990 toyota 4x4 22re. The issue is no power 1st gear is needed just to climb a small hill truck skips and idles really low. RUNS LIKE IT'S ONLY RUNNING ON 2CYL.
Things I have done ,checked timing, (used steps I found on this SITE NO ISSUES replaced TPS with used one (WILL BE RUNNING A TEST ON IT TOMORROW ) I also noticed there is no change if I unplug the TPS there is only a very small change in idling, checked wiring from TPS to ECU (no issues ) checked compression (no issues ).
Now for what previous owner did. Installed new injectors, new fuel filter, new wires and plugs,new coil,
Oh and I have two codes 41 and code 51. Also I bought the truck with this issue.
Any help would be great. Thanks
Old Jan 26, 2016 | 01:59 AM
Terrys87's Avatar
Here are the codes
Code 41 Throttle position circuit fault
Code 42 Vehicle speed sensor circuit
Code 43 No starter signal to the ecu
Code 51 AC signal on; DL contact off
You will need to get the codes cleared, especially 41. After you get it cleared, do a complete tune up with great quality parts, by the book, either a Factory Service Manual or Haynes Manual. I would not go by the previous owners word, you just never know.
Since you have worked on these before and it seems like it is only running on 2 cylinders, I would see if it is 1 and 3 cylinders or 2 and 4 cylinders as they share the same injector harness wiring. Toyota used wire crimps and they tend to corrode in some cases. They will pass a resistance check but still not allow enough voltage to pass to fire the injectors.
Find out which two cylinders may not be firing and then I would see if I am getting spark which would be the fire side and would be easiest to check. If I was getting spark, I would then check to see if I am getting fuel/ are the injectors firing, https://www.yotatech.com/forums/f116...t-22re-270857/
Here is what I went thru for not firing injectors https://www.yotatech.com/forums/f199...l#post51897320
jstluise
Jul 1, 2020 10:50 AM
SteveO13
Feb 26, 2016 03:11 PM
FRANCOARMANI
Oct 19, 2015 07:33 AM
Crazy_Guy97
Oct 18, 2015 02:46 PM
scott90
Oct 8, 2015 03:01 PM
