Sponsored by: CARiD
Newbie in need of help
Old Oct 16, 2010 | 07:15 PM
just huntin's Avatar
Newbie in need of gear help or directions
I have 33x12.5's on a 83 4x4 with 4.10 gears, it is hard on clutches; how do i put in 4.88 gears
Last edited by just huntin; Oct 16, 2010 at 09:46 PM. Reason: original title unclear
Old Oct 16, 2010 | 07:50 PM
BigBluePile's Avatar
very carefully...
Old Oct 16, 2010 | 07:54 PM
sebastianholmes's Avatar
very carefully...
very true
orrrr you could... search!!!
Old Oct 16, 2010 | 08:08 PM
myyota's Avatar
It would be cheaper if you could find some 4.88 third members and just swap them out, otherwise you would need to buy new gears and have them installed, and that`s more expensive.
Old Oct 16, 2010 | 09:42 PM
I am new to this and don't understand what third members are. Any direction to information I can read or an explanation would be awesome. What I was wondering was can I find 4.88 gears, which I understand to come from a v-6, and put them in a 4.10 axle if not what do I need to change. I believe the the gear code for 4.88's to be g144 can the g144 gears go right into the stock 4.10 axle. Thank you for any guidance
Old Oct 16, 2010 | 10:12 PM
myyota's Avatar
The third member is what the drive shafts connect to at the front and rear axles, you can swap 4.88 thirds from a V6 into 4 cylinder axles if you have a solid front axle. It would help to know what year your truck is. Just start searching and reading, all the information you could ever need it here.
Old Oct 17, 2010 | 07:59 AM
There's a whole thread on here about gears....
Big Little Bear
230
Nov 13, 2023 11:42 AM
JonG85
Jan 18, 2023 04:31 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 29, 2015 02:50 PM
