Sponsored by: CARiD
suspension
Old Nov 15, 2010 | 12:55 PM
vincepower's Avatar
suspension
Thinking of putting some new front and rear shocks in an attempt at a cheap way to improve my non existent suspension on my 94 toyota pickup. I've been doing some research and its seems like a pretty easy job. From what I can tell the main things I need are some jack stands and a jack. Is it as easy as it appears or are there some things I should know?
Old Nov 15, 2010 | 01:14 PM
J_yota22k's Avatar
There not really hard at all... i just did my and it took 10 to 15min's to do my on my toyota. And yes that all you really need is a jack and a stand too. If you have IFS and doing your strut's your going to take a few mins they are a pain to put on.
Old Nov 15, 2010 | 02:00 PM
4bangercraig's Avatar
Remember that shocks will not fix sagging ride height, ability to soak up speed bumps, or ability to carry loads. If your springs is bad, your springs is bad.
Will give you better handling and a flatter truck when you're turning though.
You did the bounce test yeah? Press down on every corner of the truck then let go. If it bounces more than once before it settles, your shocks are donezo.
You goin with Bilsteins?
Old Nov 15, 2010 | 03:14 PM
vincepower's Avatar
The reason I'm changing them is because I was taking some corners on the freeway and the truck was leaning bad, felt like it was gonna tip. As far as brand, I'm just going with some "mid" priced ones from autozone. Not getting any performance parts or anything like that.
Old Nov 22, 2010 | 10:01 AM
rattlewagon's Avatar
^^ Also check your to see if your sway bar is still attached, or if the bushings are worn out. New bushings will also help with body roll.
Old Nov 23, 2010 | 01:08 AM
duck tape's Avatar
if you still have too much body roll after the new shocks, you may want to consider timbren, especially if you haul
Old Nov 23, 2010 | 09:48 AM
brian2sun's Avatar
^^^^ this. If it contiues to bounce up and down after you hit a bump, then it's shocks. If it's just a crappy ride all around, you're springs are shot (and maybe shocks too).
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
