Sponsored by: CARiD
Will it fit ? Add a leaf...
Old Oct 24, 2010 | 11:52 PM
1993hiluxsr5's Avatar
Hey guys, i need to know if this will work or what i have to do to make it work, basicly i want to try add a leaf.
My rear leaf springs are sagging quite a bit and the front is now a fair amount higher than the back and its looking strange, so i want to add a small 600kg leaf to the rear pack to try and correct it.
the leaf springs are 3inches wide and the one i have to put in is only 2inches, will it work ?
i will have to cut down the add a leafs becuase i got them from a trailer and there not all the same lenght ( photo's) i will also have to drill out the center pin to the correct diameter, but after that is it all good to go ? ?
how do i actualy put it into the old pack ? :S
Thanks Guys i know youll have the answer
pictures:
Old Oct 25, 2010 | 04:02 AM
4Crawler's Avatar
Typically the Toyota Hilux/pickup springs are about 2-3/8" (60mm) wide. If your leaves are wider than ~2.5", may not clear the u-bolts. Narrower is OK.
How to install:
- http://www.4crawler.com/Diesel/Cheap...l#Add-a-leaves
Old Oct 25, 2010 | 01:52 PM
Thank you, I think I'm going to give it a crack tonight and see how it goes
Old Oct 27, 2010 | 12:33 AM
Good news. Despite the add a leafs being tiny they have given my leafs a new leaf on life (pun). They have also added about 2inches of lift to the rear so now the car is sitting much better
Thanks Yotatech!!
terminator
Oct 13, 2021 10:13 AM
Jake28296
Sep 3, 2015 04:58 PM
mistershmi
Aug 31, 2015 03:44 PM
klavender1
Aug 15, 2015 01:51 PM
TDonkey
Jul 26, 2015 10:14 AM
