Sponsored by: CARiD
3.0 transmission on 3.4
Old Nov 21, 2010 | 05:47 PM
572ysc's Avatar
I have a 1995 toyota t100 ext. cab 4x4 auto short bed with a 3.4 v6 and found a 1993 t100 4x4 reg. cab long bed in the junkyard it has a 3.0 5speed. can i swap the manual in my truck? if so what will i need?
Old Nov 22, 2010 | 05:55 PM
RobD's Avatar
Off the top of my head:
- transmission
- flywheel and clutch
- slave and master cylinder
- pedal assembly
- shifter boot and console
- possibly the starter
Anyone else chime in.
Old Nov 22, 2010 | 06:15 PM
just call me smithy's Avatar
the t-case drop on the two trannys differ, the 3.0 will have a passenger drop and the 3.4 will have a driver side drop, unless you plan on doing a sas or getting an adapter to allow you to have a driver side drop it wont line up to your front diff.
Old Nov 22, 2010 | 06:17 PM
t-1hundred's Avatar
well im pretty much doing the same swap to and i was able to bolt it right up to the 3.4 motor...you will need a pilot bearing which is the same part number for both 3.0 and 3.4. i pretty much used everything off my ol 3.0 which was the whole clutch and flywheel and throw out bearing. and if your using the 3.0 bellhousing you will need the 3.0 starter especially for that 3.0 flywheel and youll need the 3.0 slave cylinder, and along with the clutch pedal and brake pedal.
and as for the wiring your on your own for that one cause thats what im stuck on now and i cant figure out what to do on that part. ill let ya know if i find any info on that
Old Nov 22, 2010 | 06:19 PM
t-1hundred's Avatar
all t100s have passenger side drop t-cases
Old Nov 22, 2010 | 06:24 PM
i read to fast, i thought i said 4runner.....doh.......
Old Nov 22, 2010 | 06:27 PM
MudHippy's Avatar
See your thread, I believe I just answered that question for ya.
https://www.yotatech.com/forums/f161/totaled-t-224111/
Old Dec 24, 2010 | 12:41 PM
572ysc's Avatar
thanks guys sorry for the long time my computer took a crap on me took forever for the new one
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
Linked2002
3.4 Swaps
7
Dec 15, 2015 01:31 PM
coleypull15
Nov 3, 2015 07:41 AM
93toyoguy
Aug 2, 2015 07:41 PM
mengquis
Jul 13, 2015 10:39 AM
