Sponsored by: CARiD
4" ifs rough country lift + bj and coil spacer lift?
Old Nov 3, 2010 | 10:31 PM
ohoktimmyg's Avatar
is it possible to run a 4/5" rough country suspension lift (ifs) and a 1.5/ 2" bj and coil spacer kit on a 2nd gen 4runner? i looked all around and couldnt find anything specific..
thank you!
Old Nov 4, 2010 | 07:05 AM
bobby_duce's Avatar
yep here ya go this should help.
https://www.yotatech.com/search.php?searchid=7957742
Old Nov 4, 2010 | 07:41 AM
4banginRunner's Avatar
Yes.
Here's a Pro Comp Stage II, and BJ spacers on my 87 4Runner last year.
33s in this pic, Ran 36s NP
sittin on 265s
Old Nov 4, 2010 | 12:24 PM
JamesD's Avatar
thank you!
Yes about the front but the rears I do not know. I have the Superlift in my 2nd gen and I noticed the driveshaft is mostly extended to the max. I put the BJ spacers up front and decranked the torsion bars to give it a smoother ride in which it did. I still have 4" of lift. I guess I could crank it up even more but then you have to worry about CV joints breaking.
James
Old Nov 4, 2010 | 11:31 PM
ohoktimmyg's Avatar
Originally Posted by 4banginRunner
Yes.
sittin on 265s
truck looks good. how were your driveshafts? my friend mentioned a tranny drop may be needed but im not sure about that either.
thanks again
Old Nov 5, 2010 | 06:35 AM
xxxtreme22r's Avatar
not sure what you mean by tranny drop never head of that before, but the first thing that comes to mind with running both bracket lift and BJ spacers is the possible need for a differential drop kit. But I believe those bracket lifts already come with the needed stuff that drops the front axle anyway to keep the CV's in line.
Old Nov 5, 2010 | 10:54 AM
thanks again
Drive shafts were fine, I was running a 2nd Gen 4Runner (v6/auto) rear driveshaft (bout 1-2" longer than my stocker). Front shaft was fine.
Toyota are not *eeps....tranny drops....lmao
Diff drop? Bracket junk does "drop the diff"
Wasn't really caring about CV angles....SAS was coming.
ohoktimmyg, If you do go this route, DO use the support bars (or make some) from the trans x-member to the LCA mount.....saves you from this:
Driver tire is 2" back and 1" up from where it should be, I bent the control arm, obviously destroyed the lower bushings, fun stuff like that
Here's another pic tougher to see but I think the alignment was off
Old Nov 5, 2010 | 01:38 PM
bobby_duce's Avatar
was that at crawling speed or going alittle faster?
Old Nov 5, 2010 | 02:53 PM
It was dumb, my buddy just went through no problem (89, F150 SAS, 347 stroker, 38s blah blah blah), I followed, wouldn't have been the slightest problem except for the ice. Dumb reaction was to hit the brakes, she slid and hit hard, bounced it, heard nice snaps and bangs, thought the knuckle was gunna be laying on the ground haha. Drove it home! pulled super hard to the d-side but w/e.
SAS FTW
Old Nov 5, 2010 | 03:50 PM
bobby_duce's Avatar
haha ouch
Old Mar 9, 2011 | 02:25 PM
ohoktimmyg's Avatar
Ok so i am just about ready to lift my truck and I want to order the rest of the parts i need. if its possible i would like to try to get it all from the same place at the same time for shipping reasons.
I want:
2-3 coil spacers for back
1-2 inch BJ spacers
4 shocks that will fit a 5-7 inch lift on a 93 4runner
a steering stabilizer
If anyone could help out I would really appreciate it. I wanna order this stuff before my tax return all goes to the local bartenders
Thanks!!
Old Mar 9, 2011 | 03:52 PM
ohoktimmyg's Avatar
How about these?
http://cgi.ebay.com/ebaymotors/Alumi...ht_1229wt_1167
How about you guys just recommend places where you buy your parts?
thanks!
Old Mar 13, 2011 | 10:43 PM
shooterN19's Avatar
If I have a 4in suspension lift for ifs should I use that instead of doin the cheapier lift with the ball joint spacers?
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Yotoder865
Jul 9, 2015 07:51 PM
