Sponsored by: CARiD
strange noise
Old Nov 13, 2010 | 04:11 PM
luckycraftsammy's Avatar
Question strange noise
hello peoples got a problem i just did a timing chain on my 94 yota 2wd everything went good and it was my first time doing one but i got everything back together added my fluids and did my timing and it is balls on 5 btdc. but i have a noise that sounds like its coming from the oil pump it almost sounds like a turbo spooling when i rev it all my parts are brand new fellas i need help its driving me nuts thank you
so i took the oil pump to see and what i found is that the oil (which is new)was milky white so i cleaned it and reinstalled everything and took to a shop because im lost i dont know what can be causing this does any1 here know
the noise problem was the alternator bearing and the milky white oil was because i used brake cleaner to clean the timing cover
Old Nov 13, 2010 | 04:48 PM
Teuf's Avatar
Are the belts new? Maybe a break in period is needed.
Old Nov 14, 2010 | 09:21 AM
yep everything is new but i did drop the gear out of the oil pump is there a certain way the gear goes it???
Old Nov 14, 2010 | 09:23 AM
Teuf's Avatar
Do you have an FSM, that should help.
Old Nov 14, 2010 | 09:24 AM
Teuf's Avatar
/Users/pauldyer/Desktop/TOYOTA FOLDER/AAAAAA FSM 1988.pdf
Teuf's Avatar
OOPS can't forward link sorry.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
