Sponsored by: CARiD
what kind of damage am i looking at if i run 37s with stock ifs 410s with the 22re?
Old Oct 8, 2010 | 11:50 PM
4runner dude's Avatar
locked in the rear. and have 9 inches of lift. so plenty of clerance to run them.
is it gonna break anything? how bad of gas mileage?
how bad is my speed gonna be scrwed up?
Old Oct 9, 2010 | 12:21 AM
Black_1985_SR5's Avatar
you will be doing 0-60 in like 21 seconds vs 15 stock speedo will be way off, you could break axels
Old Oct 9, 2010 | 12:28 AM
this is what its like with a fresh motor a big cam and 5.29's with a 22re and 36's
http://www.youtube.com/watch?v=K_4TNTG8l6o
Old Oct 9, 2010 | 01:12 AM
1993hiluxsr5's Avatar
i do 0-60 in about 90 seconds and i only run 33's haha
Old Oct 9, 2010 | 06:27 AM
87hillbillyoter's Avatar
well i got 33s with stock 4.10s on steelies, mods to the engine in my sig. i gotta say that its not fast at all. i timed 0-60 at 19.2 seconds, with a tailwind lol. 37s with 4.10s would probably burn your clutch out real quick, and i think its called the idler bar or something? i guess bigger tires on IFS break that... i dont know. theres a guy on here thats running 37s, and no lift on ifs. maybe hell chime in. oh and im sure your cvs wouldnt like it
Old Oct 9, 2010 | 11:16 AM
MudHippy's Avatar
No, the clutch isn't going to like it and you'll also be adding strain to the entire drivetrain besides that(engine, tranny, transfer case, driveshafts, differentials, axleshafts). And especially all front suspension, front axle(CVs, differential gears, hubs), steering(it's called an Idler Arm, not Bar)and braking components.
37's with no lift?
What kind of other modification was necessary? I can think of many things that would NOT work without something being done to address them. I can barely squeeze by with my 35's on 3.5" backspaced rims and 5" of lift(3" body lift, 2" suspension).
I'd sure like to see some pics of how he's done that anyway. I bet it took some serious work.
Old Oct 9, 2010 | 11:33 AM
well im running a new 22re. bored out. the new head style. rv cam. all new injectors. new clutch. i dont know what wrong with your yotas. but im running 33s with 410s and can get up to 60 in about 10 seconds with a locked rear end. and thats keeping it under 4500 rpms.
shouldnt break anything if i slap a pair on to try it right? do a couple take offs and see how it does off road for a day?
Old Oct 9, 2010 | 11:44 AM
usmc-lazer's Avatar
The truck will have no power at all.
Old Oct 9, 2010 | 12:59 PM
93yotaSR5's Avatar
what the truck? youll be sorry you did it
Old Oct 9, 2010 | 01:03 PM
Flash319's Avatar
Nothing. A 22re can't break itself.........
Old Oct 9, 2010 | 01:55 PM
yoder519's Avatar
im runnin 35s with a fresh motor and 35s on my DD. its not terribly mad if you ask me, but id like to regear. i dont use 5th gear anymore, 4th gear is perfect fro 65-75MPH. youll prob be usin 3rd as your passing gear. its gonna SUCK pullin out on hills with 4.10s and 37s. youll prob smell your clutch burnin everytime.
i think 87yotabro87 is talkin about a 85 SFA runner with 37s and no lift. type is 37s no lift in the search.
your CVs should be fine on pavement. not liek there gonna snap instantly because on the weight on th e37s. they may be scared to death and fearing for there life, but theyll probably be okay fro DDin
Old Oct 9, 2010 | 02:42 PM
BajaRunner's Avatar
Black 1985 : Your engine sounds like it has plenty of power! I can't do that with 30" tires.
Old Oct 9, 2010 | 03:24 PM
strykersd's Avatar
How does your truck have 9" of lift? Bracket lift, body lift and BJ spacers? How are your CV angles with that much lift.
You will have zero power. What do you use your truck for? Mall crawler, mud, rock crawler? If it's just for looks, I think you can do it. But if you want to play in mud or crawl up a rock, 37s with stock t-case gears and gear ratios just won't cut it.
But to answer your question, your setup will kill steering parts. Idler arms and tie rods. If you wheel your truck hard, you'll have issues with CVs. It'll help if you install a front locker, so that if you lift a tire and the tire in mid air spins then comes down and gets traction, it'll be spinning half as fast with a locker, hopefully saving your CV from snapping in half and possibly cracking your ring gear like I did.
Old Oct 9, 2010 | 03:28 PM
yoder519's Avatar
x2 on teh 4lo. itll be higher with 37s. mines quite high with 35s
Old Oct 9, 2010 | 05:00 PM
i think it was on this forum or maybe it was marlincrawler this guy is runnin 37s on no lift ifs for sure. ill try and find him.
Old Oct 9, 2010 | 05:08 PM
yep here it is i didnt look hard enough for any more threads so here ya go
https://www.yotatech.com/forums/f116...runner-213680/
Old Oct 9, 2010 | 07:38 PM
Drunner's Avatar
37's with no lift?
This is possible the guy who bought my old 4runner put a 1inch body lift on and cut the feners. He had 37s on it. If I was going to try what your talking about I would get some gears also.
Old Oct 9, 2010 | 08:18 PM
rattlewagon's Avatar
Im more concerned with the 9" of lift. does not sound safe.
I say do it. The only way for you to truly know how its going to be is for you to do it your self. Yesh, its gonna suck, drive like Crap, and your prolly gonna break a bunch of stuff, but why not. they makr replacement parts for these every day. So I say do it and they come back and tell the rest of us how it went.
and dunner, i have 35s with no lift on my 92. im sure with a little more tubbing 37s could fit. anything is possible with a grinder and a welder.
Last edited by dropzone; Oct 9, 2010 at 08:44 PM. Reason: censor picked up cussing
Old Oct 9, 2010 | 08:49 PM
dropzone's Avatar
Fossilized
borrow a GPS to figure out your speed.
you are probably gonna end up with some front fender damage at full lock and a stuffed tire. Know how to replace a front CV axle yet?
The truck in your avatar doesn't look like 9" of lift if that is the truck you are talking about.
Old Oct 10, 2010 | 12:05 AM
vital22re's Avatar
totally a bro
I want to see the "9" " lift...
with 37's you'll make a slow truck slower and take a lot of life away from your clutch and brakes.
