Sponsored by: CARiD
Lift?
Old Nov 2, 2010 | 05:53 PM
InsaneXxPenguin's Avatar
Lift?
Hey guys, i recently bought a 94 4runner v6 4x4. I eventually plan on doing a suspension lift when i get the money but for now I want to do a body lift. What things would i need to change to install a 3" body lift compared to a 2" lift. Im planning on getting a transfer case crossmember from budbuilt with a drivetrain lift to match the body lift so i dont have to worry about the shifter, but what else would i need to replace to do a body lift (either 2 or 3") Which lift would be easier and look better?. Thanks
Old Nov 2, 2010 | 06:00 PM
Redneck08's Avatar
Between the body lift and the new x member, you might as well fork up the extra few bucks for a suspension lift.. But if you do a 3" body lift, everything should come with the kit that ya need.. Shifter extenderes( pieces of metal rod) might not need to be put in, both of my rigs have 3" body lifts and neither of them needed the shifters extended.. Hell in the tacoma the radiator didn't even need to be dropped.. But i would just save up a bit for the suspension lift, you might be able to find one used for pretty cheap?
Old Nov 2, 2010 | 06:10 PM
BigBluePile's Avatar
See: 4crawler.com for all your body lift needs.
Old Nov 2, 2010 | 06:11 PM
mightymouse's Avatar
Dude,,, first welcome. With that aside your first post is in the wrong section, a frequently asked question easily found by searching. Do some research and be happy the mods didn't line you out in your first post. Here i'll give ya some direction check here and get to reading!
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Search and learn before you post and trust me if i didn't tell ya some one else would have come along and said it in a less than polite way.
Old Nov 2, 2010 | 06:12 PM
The thing about a body lift for me is that its a automatic, so i cant find a kit for it ive seen the adapter for it but id rather just get the crossmember and lift the transfer case for more clearance. since im doing that will a body lift kit for a manual transmission work?. also when i do the suspension lift i want to do a solid axle swap. could someone tell me what is reguired for a solid axle, and what i can get one out of? thanks for any help
Old Nov 2, 2010 | 06:18 PM
Redneck08's Avatar
There is a ton of info out there for a solid axle swap, definately gonna need to do some reasearch on that one.. In a sense, doing a solid axle swap is a "suspension lift" in its own.. Don't go buying a drop down kit for a independent rig if ya plan on SAS'n it.. I would start piecing parts together for that, you get get kits from marlin, all pro, trail gear, etc.. But track down a toy axle out of a 85 and under toy.. just skip the body lift if ya wanna go that route..
Old Nov 2, 2010 | 06:36 PM
Did someone mention 4crawler yet.....
Old Nov 2, 2010 | 06:41 PM
Redneck08's Avatar
Definatley recomment 4crawlers body lifts! Very nice lift, i put one in for my buddy on a tacoma, nice lift for sure! Plus he is a cool guy to do business with
Old Nov 2, 2010 | 09:55 PM
Cam72SS's Avatar
lol
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
