Sponsored by: CARiD
about to pull trigger on 33x12.5x15 quick question
Old Nov 17, 2010 | 12:54 AM
thisgsx's Avatar
as title states, once the tires get here everything will be installed at the same time.
lc coils
2" front bj spacers
all necessary brackets; panhard, diff, swaybar, etc...
15x8 black crager soft 8s 4"bs
goodyear wrangler duratrac 33x12.5x15
my question is, without regearing how slow is acceleration going to be from 1st gear to 2nd? Uphill? Braking?
vehicle is a '90 4x4 3.0 v6 5spd
Old Nov 17, 2010 | 04:28 AM
xxxtreme22r's Avatar
you should be fine for the time being. I've seen a 3.0 4runner on the trails with 33's and factory gears, it did fine, well, mashing the gas too much IMHO but held together to my amazement.
Old Nov 17, 2010 | 04:35 AM
cootees's Avatar
acceleration and braking are not that bad. Uphill on a freeway.. thats another story but there is not much that you can do about that.
Old Nov 18, 2010 | 10:06 PM
thisgsx's Avatar
thanks for the help guys!
Old Nov 18, 2010 | 10:14 PM
87hillbillyoter's Avatar
not too bad at all. it is a little bit slower but it can be lived with haha. you might want a little less backspacing on the rims though if you dont want them to rub
Old Nov 19, 2010 | 12:44 AM
thisgsx's Avatar
how much rubbing will i get with the 4" bs? the wheels are already here and i don't really want to exchange it and have to wait a few more days for the new wheels.
Old Nov 19, 2010 | 03:50 AM
richf's Avatar
I think 3.75" back spacing is the norm around here. I have 3.75" BS on my 85 with no rubbing but it's a solid axle. You can also use a wheel spacer if it does rub.
Old Nov 19, 2010 | 07:59 AM
bobby_duce's Avatar
id say go for it and if your not happy with acceleration up hills you can re-gear later!
Old Nov 19, 2010 | 08:03 AM
Outsane's Avatar
Couple of suggestions while your putting on new rims
and Mark the inside of the rims with your contact info if some one steals your rims..
Airsoft BB's
Old Nov 19, 2010 | 08:32 AM
well then id slap em on there, turn em to full lock and if they rub, then start cuttin haha should be fine. mine have 3.25 bs and they arent even close to rubbing so you should be fine. make sure you post up some pics when you get em on there!
Old Nov 20, 2010 | 01:42 PM
limon32's Avatar
Post some pics and report on the tires, I've loved that looks of that tire since they came out but I only run my summer tires about 6 months a year and they aren't even close to being worn out...
I run the same size on the same truck, don't try to tow much of anything on the freeway, hills are ok just gotta shift more. I plan to re-gear some day but it hasn't been bad enough to make me re-gear for 2 years now!
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
Jnkml
Jul 6, 2015 01:20 PM
