Sponsored by: CARiD
shifting problems
Old Oct 15, 2010 | 08:33 AM
svtt100's Avatar
shifting problems
my 96 T100 will not shift when cold and when it does shift it shifts at 5000rpm i replaced the ect sensor already need help asap
Old Oct 21, 2010 | 12:52 PM
brian2sun's Avatar
If it's like my 4runner, it will not shift normally when the engine is not up to temp. O/D won't work at all on mine and it won't go into 3rd till ~3K rpm. 5K is high tho to shift from 1st to 2nd. Does it shift normally when the truck is warmed up?
Old Oct 21, 2010 | 05:38 PM
bobby_duce's Avatar
check your tranny fluid, it might be low? it should be a pink color.
Old Oct 21, 2010 | 06:30 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
How bout this...
What does your owners manual say about this?
As far as I know, AT Toyota's do not shift into OD unless the engine is warm. Which is even harder to do when you're jamming cold air under the hood.
You want to kill your AT prematurely? Fire it up and drive off every cold morning for all I care.
Some mechanic and his family somewhere will be glad you did.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
