Sponsored by: CARiD
Yota choking down
Old Nov 1, 2010 | 11:13 AM
yota44's's Avatar
Yota choking down
I have a 1993 Toyota pick-up on 44's it has a rebuilt 22re. When the truck is stopped and at idle and I punch the gas it stumbles and chokes down. Also, while driving down the road when I shift into the next gear I lose about 1500 rpm. I would appreciate any and all ideas to solve this problem.
Old Nov 1, 2010 | 11:26 AM
bobby_duce's Avatar
what gearing you have? well for starters any 4 cyl with 44" tires would have problems if you "punch it" from a stop. just saying.
Old Nov 1, 2010 | 11:27 AM
blake.nemitz's Avatar
clogged air filter, fuel filter? stock gears?
Old Nov 1, 2010 | 11:30 AM
xxxtreme22r's Avatar
I would think with even the correct gears and 44's any engine except a SBC SBF or a SC'd 3.4 would bog down. Why are you punching the gas at idle from a stop anyway, it's not a drag car.
Old Nov 3, 2010 | 08:40 AM
yota44's's Avatar
I'm sorry that I did not make myself clear It happens when the truck is sitting still in neutral,not moving. As for gearing I am not sure what gears are in it. I want to be able to run the truck before I worry about gears. I have checked: air filter, the throttle position sensor, and for vacuum leaks. I have replaced: fuel filter,spark plugs, rotor plug, VAFM, and the igniter. Any suggestions would be appreciated.
Old Nov 3, 2010 | 09:01 AM
were you doing any maintenance before any of this started? ie timing chain job, oil change etc etc?
a video of this happening would probably be a good thing as well.
Old Nov 3, 2010 | 11:10 AM
yota44's's Avatar
I rebuilt the motor in may and it was doing great then my brake caliper came off and broke my rim so it sat up for about two months till i got the money to replace it and when i got it replaced I drove it and new something wasn't right. It seemed as though the timing was out at first so i brought it to a mechanic to get the timing set because i didin't have a timing light and ever since then it has been acting this way.
Old Nov 3, 2010 | 02:31 PM
OrRunner's Avatar
id get a timing light and re-check the timing......
Old Nov 3, 2010 | 03:05 PM
you could try timing it the old school way keep advancing until the idle stops going up and starts stumbling then back off a hair
Old Jan 5, 2011 | 05:57 PM
yota44's's Avatar
I reset the timing and it seems to do a lot better now. I am still having problems though when i drive it, it seems that there is a spot in the trottle when it gets no gas if i stay before or after it the truck runs good. I checked the fuel pressure and according to my research it is supposed to be between 27 and 33. My fuel pressure is around 22. I have replaced fuel pump, fuel filter and tried a fuel pressure regulator off of a different truck. Any suggestions on what could cause low fuel pressure?
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
