Sponsored by: CARiD
Replacing a leaky radiator
Old Nov 27, 2010 | 10:28 AM
Dirtfloorfab's Avatar
well I went to replace my leaking radiator and that went oknow got the new one in I took out the afm to make sure I didn't get anti freeze on it I buttoned it all back together to start it and it started and stalled then when I went to start it again there where no lights on on the dash and it wouldn't roll over I looked under the hood and the afm plug wasnt plugged in I plugged it back in and still nothing I un plugged the battery and I havent tried it since is there a fuse I maybe blew or is my ignition toast any help is greatly appreciated
Old Nov 28, 2010 | 05:56 AM
Bump anything to check would be really helpful I've checked the battery and the wire extensions so far
Old Nov 28, 2010 | 01:29 PM
wyoming9's Avatar
Red face
I have changed countless radiators.
Why would you think you would get coolant on the afm.You don`t think water gets in there when you drive through a puddle that is just below the doors.
The very first thing you do is drain the coolant
If it does not crank look at your battery terminals then check your grounds.
Was anything sparking or arcing any where.
even if the AFM plug is out it should still crank.
if the plug is not in correct it might not turn on the fuel pump. Maybe you bent some pins on the plug
Old Nov 28, 2010 | 01:51 PM
myyota's Avatar
If everything is dead, check the battery and battery terminals, if that`s good, check the wire from the battery to the fuse box, its known to break, and also check the 80 amp main fuse.
Old Nov 28, 2010 | 03:46 PM
Ok I'll check the terminals again and the main fuse I just didn't know what one it was so ilk check it when I get time
Old Nov 28, 2010 | 03:48 PM
Oh and I was switching to aluminum 90° intake elbow so I took it out
Old Nov 28, 2010 | 04:04 PM
zerothought's Avatar
x2 on checking all your grounds,i had a heck of a time with a starter issue in my old jeep one day because the ground from the engine block to the chassis was loose/corroded.
Old Nov 30, 2010 | 05:39 PM
Does the motor have to be grounded i removed the one to the block when I did the intake battery swap now all that's grounded is the fender
Old Dec 1, 2010 | 02:14 PM
breknraj's Avatar
Yes, you want a SOLID (read - heavy duty, not solid wire) ground between the engine and chassis.
If you removed the engine ground, then you have mostly isolated the engine from the chassis and battery.
Old Dec 5, 2010 | 01:15 PM
ok im gunna get that hooked up tonight ill see how it goes i guess the fuse is still good im hoping its just the ground
Old Dec 5, 2010 | 03:38 PM
Got it rewired new grounds and it started up and ran like a champ thanks for the help guys
Old Dec 6, 2010 | 05:04 AM
rattlewagon's Avatar
Glad you could get it figured out!
Road Bull
Oct 10, 2015 04:55 PM
Rkellerman
Jul 12, 2015 08:42 AM
Poncho0206
Jul 10, 2015 06:21 PM
horunner1x
Jul 10, 2015 06:33 AM
Avenged
Jul 9, 2015 07:55 AM
