Sponsored by: CARiD
Bar's Leaks
Old Oct 22, 2010 | 04:11 AM
Vanman's Avatar
Bar's Leaks
Does this stuff work, or is it all hype?
I have a leak, can't tell from where. Drips down from somewhere above the front right shock, on to said shock, then on to the floor. I had posted a while back about it possibly being the power steering pressure hose (mech's opinion a few months ago), but my power steering fluid level hasn't changed. Plus, it looks and tastes like reg. motor oil.
It isn't a huge leak, 'cause I seldom have to add oil to the engine between changes. I does drop a bit, but maybe only 1/4 quart. Some of that suppose could be burning off as well. But leaks do not get better by themselves, so...
Just wondering if any of those additives work on older engines.
Got 166,500 on the '91 4Runner (I think I can get a collector plate next year!).
Thanks!
Old Oct 22, 2010 | 05:27 AM
WhiteKnight's Avatar
Ive used it twice. It worked great the first time and not at all the second. But i used it for an intake leak. I havent used any of their oil additives.
Old Oct 22, 2010 | 05:36 AM
Swimmerboy2112's Avatar
Give it a shot, you got nothin to lose. And its 25 years for a collector plate. 1 more year for me!
Old Oct 22, 2010 | 07:21 AM
mightymouse's Avatar
lucas oil makes a good engine oil stop leak that i would reccomend. It's just like a normal oil additive and you use it a couple times when you change your oil.
Old Oct 22, 2010 | 07:57 AM
xxxtreme22r's Avatar
I swear not to use that kinda stuff in my motors or anything else. It gums up everything including stuff it's not supposed to. Find the leak and fix it right.
Old Oct 22, 2010 | 08:13 AM
Vanman's Avatar
That is what I worry about. Maybe there is something holding the engine together, that when "treated" will cause the darn thing to fall apart
It is at the mechanic now. He said that even if he does find it, it might not be worth fixing, considering I seldom add oil between oil changes. I only put about 5k-6k on it a year (my daily driver). Other than the mpg (and saggy rear end, rear passenger power windows not working, and "some" rust), I like the thing.
I forgot to ask the mech what he thought of the additives, although I can guess what his reply will be.
Thanks for the replies.
Old Oct 22, 2010 | 08:25 AM
1styota4X4's Avatar
dont use them i just pulled a part a motor and the thermo housing had gelitan clogging it from a water leak stopper....its a mess. The lucas oil additive is good its like pouring honey in the motor lol. I have used it many times its not listed as a leak stoppere just a really thick additive that will help plump up seals.
yotarob2005's Avatar
Def. do not put the Bars leak in.
Old Oct 22, 2010 | 09:08 AM
wyoming9's Avatar
Red face
For what it`s worth I have a 1983 Celica 22REC that when I got it had some slight oil leaks and burned some also.
Using Lucas oil additive it quit leaking and burning oil by the 3rd oil change in the roll of daily driver.
I also mix this with the gear oil also
Old Oct 22, 2010 | 10:36 AM
sethb's Avatar
Could be your cam seals, when was the last time your timing belt was changed out?
Also, is there any gunk on the front of your motor? Does it only leak when it's cold? And, there's not such thing as "not being worth fixing." Eventually, whatever it is could cause a catastrophic failure and leave you stranded somewhere, not to mention the small but unnessescary impact on the enviroment. If it's leaking and your mechanic says you shouldn't bother, find a different mechanic or do it yourself. Do it right the first time and you'll avoid more headaches down the road.
Old Oct 22, 2010 | 06:25 PM
Vanman's Avatar
Got the Runner back, and the mech said he really couldn't tell where the leak was. Said something about pulling the engine if I really wanted to know. He said that would be a lot of money. Any one of you guys live out my way
I asked him about the oil additive stuff for leaks, and he said he has never used the stuff, just fixed the problem.
I suppose I could take it to a dealer... I am sure they would spot the problem.
Thanks for all the input.
Old Oct 22, 2010 | 07:13 PM
Resto-noob's Avatar
Where exactly do you live?
Old Oct 22, 2010 | 10:30 PM
seriously if you're only loosing a little oil between changes just get the lucas oil stuff. it doesn't hurt any thing and most likely stop the leak. It reconditions seals and make your motor happy. You have very little to nothing to loose with it. this stuff. Will not hurt your motor just read the instructions and use it next oil change.
Old Oct 23, 2010 | 05:42 AM
Vanman's Avatar
Live in NW Minnesota....
BTW, the mech I took it to wasn't looking for extra work, as he said he wouldn't do the stated engine pull.
I wonder how I can add some of that stuff now...I'll read up on the Lucas stuff.
Thanks
Old Oct 23, 2010 | 04:18 PM
Resto-noob's Avatar
Thanks
I would love to go to NW Minnesota. I'm sure the fishing there is outstanding.
What about changing the oil to a high mileage oil and then adding the Lucas?
Blamalam
Mar 12, 2022 07:34 AM
4.34runner88
Aug 11, 2018 10:44 AM
andrewtexas123
Jul 6, 2016 01:49 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
defrag4
Jul 31, 2015 10:50 AM
