Sponsored by: CARiD
What could cause my high oil pressure?
Old Jan 30, 2008 | 07:53 PM
934runner's Avatar
After doing my main and rod bearings in a 93 3.0liter.when started up my oil pressure was extremly high and before my oil pressure was 4psi to maybe 20psi Now it gos right up to 75+psi and after ran for about five min noticed i had oil leaking from up top behind timing belt cover.I didnt do anything with the oil pump but cleaned off old gasket and put new gasket sealer from toyota on and torqued the bolts to spec.Any info would be helpfull Thanks
Old Jan 30, 2008 | 07:58 PM
HuskyRunner's Avatar
Welcome! Could it be something as simple as you over-filled it? I know in my work truck (non-Toyota) if I over fill it the guage reads high - but within a couple days it's back down where it should be - it used a quart every two weeks like clockwork.
Old Jan 30, 2008 | 09:47 PM
934runner's Avatar
Tipstick says its right on full
Old Feb 1, 2008 | 05:40 PM
Full while cold or hot?
Old Feb 1, 2008 | 07:53 PM
jason191918's Avatar
I installed a mechanical oil pressure gauge, so I know what the numbers are. When using 10w30 it ran about 80-85 pounds cold, but when warm runs just under 40 while cruising. Now that I changed the oil, even tho it is 5w30, it runs 90+ when cold, but when warm all is good. Is this normal, or do we both have problems?
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
