Sponsored by: CARiD
Accessory Belts
Old Mar 1, 2008 | 12:46 PM
electricsoul's Avatar
Accessory Belts
Hi all,
I am changing accessory belts on my 93 4runner (V6). I am wondering where the tension release is for the power steering belt??? From other posts I gather the alternator belt can be released by loosening the alternator bolts and wiggling the belt free.
Help is much appreciated!
(also any warning/suggestions from your experience is greatly appreciated)
Old Mar 1, 2008 | 12:49 PM
DeathCougar's Avatar
Loosen the PS pump and wiggle the belt free.
Only the AC pump has a seperate idler bearing/tensioner.
Old Mar 1, 2008 | 01:42 PM
Thank you for your amazingly quick reponse DeathCougar! I will try it.
Old Mar 1, 2008 | 01:47 PM
The upper bolt is the pivot bolt IIRC, and a major PITA to get to. You will need only a 14mm wrench for both bolts. The slide bolt (that slides on the bracket) points backwards on the pass side of the pump. Sorta hard to type it out on the net and have it make sense. If you look down there, you will be able to better see what I mean.
Old Mar 3, 2008 | 06:38 PM
Thanks for taking care of us newbies!
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
TransAmBandit
Sep 20, 2015 06:08 PM
