Sponsored by: CARiD
33's on a 4 banger
Old Feb 13, 2008 | 01:16 PM
yoder519's Avatar
33's on a 4 banger
i gotta 95 yota pickup 4 cylinder 4x4 and i was wantin to put a 5inch rough country suspension lift with 33x12.50's. would it be hard on my truck with the 33s since its a 4 banger?
Old Feb 13, 2008 | 01:22 PM
Elvota's Avatar
What tranny?
Any hills in your area?
DD or trail only?
With stock gears, it's going to be slower. Upgrading to 4.88's would give you a chance at HWY driving.
I drove a 4CYL auto with 33's and stock gears for many, many miles and did all right. I just didn't pass anyone.
Old Feb 13, 2008 | 01:29 PM
AxleIke's Avatar
It'll be fine.
Regear and it will be perfect.
Old Feb 13, 2008 | 01:34 PM
Tacoclimber's Avatar
I ran 33x12.50's on my 82. Wasn't bad at all.
Helped having a Weber carb on my 22R, but I digress...
Old Feb 13, 2008 | 04:07 PM
bigarms23's Avatar
you wont have problems it will work fine
Old Feb 13, 2008 | 04:10 PM
Dare44's Avatar
my 91 with a 22re does perfect with 4.88 gearing, still isnt a racecar
Old Feb 13, 2008 | 04:11 PM
waskillywabbit's Avatar
My 4banger will bark the tires....39.5/13.50/15 Iroks. It is all about how fresh the engine is and your gearing.
Old Feb 14, 2008 | 06:33 AM
JLSpeed's Avatar
I have 305/70/16's on my 4 - it's slow, but it's always been slow...... it moves in 4LOW though!
Old Feb 20, 2008 | 02:26 PM
yoder519's Avatar
i aint to sure what tranny she has..
and its kinda of hilly around here but not really..
do u know of any cheap mods i could put on it to giver a little more git up and go?
Old Feb 20, 2008 | 02:53 PM
camo31_10.50's Avatar
what they mean by what kind of tranny is...is it a 5spd manual or an automatic..if its automatic then you will want i think 5.29's or 5.71's...if its a 5spd then u will want 4.88's unless u want to go up to 35's sometime soon if so get the 5.29's...im not familiar with the EFI setup...but hopefully some of the other ore experienced guys will chime in
Old Feb 20, 2008 | 03:26 PM
85toy's Avatar
it will work fine it will just be a little slow.
Old Feb 20, 2008 | 03:27 PM
NwRunner's Avatar
My friends 89 pickup with the 22r has 33's and it seems like his truck wants to die whenever we come to a hill. And its decreased his gas mileage by 1/4 of what it was stock, but his also has 200,000+ miles. It all matters on how well youve treated your engine/tranny, and regearing would help to.
Old Feb 20, 2008 | 04:48 PM
mrnick1979's Avatar
it will be fine , if you plan to tow a boat you will never see 5th gear with out regearing, been there done that.
Old Feb 20, 2008 | 04:51 PM
mrnick1979's Avatar
the truck you see under my screen name had 33,s but i also did alot of mods to the 22re probably added 40hp and it had plenty of go go juice in it to pull the tires at hwy speeds, if your motor is stock it will kill your mileage but it will work fine.
Old Feb 21, 2008 | 03:44 PM
yoder519's Avatar
oh my bad yea its a 5 speed
Old Feb 21, 2008 | 03:55 PM
yoder519's Avatar
any of yall have any trouble when its in 4low puttin in back inta 2?
Old Feb 21, 2008 | 05:51 PM
jsn_stockard's Avatar
I am running 33's on my 92 4 gunner toy, and it does fine. No gears, or lift, just a bit of trimming and fab work in the corners. I drive it on the highway and can still run 90, if the wind permits. The pic shows 31's on it, but that is an old pic.
Old Feb 21, 2008 | 06:04 PM
Dare44's Avatar
yeah when going from 4wd to 2wd in mine u have to pull forward with pressure on the transfer case shifter to get it in, slides right in like that
crammit442
7
Nov 29, 2017 12:30 PM
smilen724
13
Nov 8, 2015 04:11 PM
jerusry
Oct 19, 2015 05:28 PM
skeeter0288
Aug 16, 2015 09:40 PM
