Sponsored by: CARiD
85 Yota Timing/Injector Question
Old Jan 30, 2008 | 07:43 AM
85MudYota's Avatar
Ok, i bought a 85 Toyota with the 22re engine. The guy told me he replaced head gasket but when he did, he didnt mark the plugs for the injectors. So he told me i would either have to get engine harness to make it easy or trace the wires back. Well i tried starting the truck yesterday with the injectors like they were and i used starting fluid in the intake and it backfired out of the intake. Some say thats timing, well im new to this so i dont know how to adjust the timing. Can any help me out???
Old Jan 30, 2008 | 07:52 AM
rdlsz24's Avatar
Download the field service manual for your truck here: (it's best to right-click and then save as)
http://www.ncttora.com/fsm/1985/1985FSM.pdf
That should tell you everything you need to know.
Rob
Old Jan 30, 2008 | 08:17 AM
85MudYota's Avatar
Thats a big file...haha....this truck is so rigged, its making me mad, i looked and some plugs are not plugged up and i cant see no empy spots. One wire is coming out of the plug.....grrrrrrrrr.
Old Feb 6, 2008 | 07:06 PM
Blacksmith04's Avatar
I understand about trucks being rigged. I just bought a 86. started burning oil afther the first oil change. Bad valve seals. I flushed it and changed the oil again now the oil psi gauge works but smokes more and now have a blown head gasket. I was going to have the head redone,but found a new head online for the same price. While I'm in there I will be replaceing everything that can be replaced. The guy that owned it before me liked to use rtv for everything. I will probably find some on the head gasket.LOL This truck will rock when done.
shisha1999
Aug 14, 2015 01:33 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
nonstop
Jul 24, 2015 06:29 PM
