Sponsored by: CARiD
open wire connecters..
Old Feb 5, 2008 | 11:11 PM
Scooby098's Avatar
open wire connecters.. have some on the passenger side and driver side only a few. does anyone know what these are Sposed to go to? first 3 are on the passenger side last 2 would be on the drivers side Its a 83 Pickup, thanks again
Old Feb 5, 2008 | 11:18 PM
apalmer1's Avatar
That green one in the first picture is the orriginal connector from the factory alternator, the one i mentioned in the last thread. Not sure about the others.
Old Feb 5, 2008 | 11:26 PM
Scooby098's Avatar
really.... I wonder If I should try and tapping into it? with this one. And one wire on that plug has been rerouted to supply power to the fuel pump witch is next to the fire wall gotta love how people wire old rigs
Old Feb 5, 2008 | 11:32 PM
apalmer1's Avatar
i would just try taking that black wire you jumped from the connector terminal to the hutlug and running it to the battery instead of the hot lug. Id be willing to bet that will solve your problem. Its not like its gona be able to find voltage from the back of the alternator when there is no voltage going into the front to make it produce output in the first place.
Old Feb 5, 2008 | 11:47 PM
Scooby098's Avatar
Rodger that. I guess I should ground the other side then If I do that? cause from what youve told me that since its not getting any amps from the battery its not sending enough amps to charge the battery, that why it would go dead but put out maybe enough amps to give it a small charge enough to run it correct? Ill try that,.
Old Feb 6, 2008 | 12:04 AM
apalmer1's Avatar
Yeah i would try just running the positive lead to the battery first, and see if that works, and if not then try grounding the other prong.
Old Feb 6, 2008 | 12:05 AM
Scooby098's Avatar
Rodger that Thanks a million lol I was almost prepared to go out and buy a new 110 amp that wouldive hurt the wallet for sure.
okamikai
Apr 30, 2018 10:19 PM
theking11863
Mar 19, 2016 09:36 PM
toofly1999
Jul 25, 2015 07:09 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
jackiebrownia
Jul 20, 2015 09:02 AM
