Sponsored by: CARiD
wheel problem
Old Feb 1, 2008 | 06:04 PM
89trknwby's Avatar
wheel problem
hello. i'm new to the site and to oyota trucks. first , the site is awesome. I bought a 89 toyota pick up(22re, 5 spd, 4x4). gave it a tune up , fresh fluids, ordered a hi flow cat(not installed yet), and put new shocks on it. the promlem is when I went to put the new shocks on I could not get the front tires off of the truck. I know I sound stupid but I didn't know if there is a trick . I used a rubber mallet on the back side and tapped on it. I didn't hit it hard for the fear of breaking something. I need to get these off because it need tires and I would like to service the brakes. Thank you for any help .
Old Feb 1, 2008 | 07:25 PM
4Crawler's Avatar
Probably rusted in place. For a simple removal method, leave the lug nuts loose and roll the truck forward or back a little to see if the weight breaks the wheel loose.
Old Feb 1, 2008 | 07:46 PM
jason191918's Avatar
I usually just beat the rubber w/ a BFH.
Just make sure you do it in a circular fashion.
Old Feb 1, 2008 | 08:08 PM
93caddyrunner's Avatar
had the same problem soak around the hubs in wd40 or pb blaster or what ever lubricant you have then beat on the back with a hammer and pull on then until the come off
Old Feb 2, 2008 | 10:00 AM
89trknwby's Avatar
thanks . is this a common problem or is that the last owner didn't maintain it properly? thanks again.
Old Feb 2, 2008 | 05:46 PM
bigarms23's Avatar
soak it i used a lub from justice brothers which is basiccaly 2x the power of wd40
Old Feb 2, 2008 | 08:00 PM
Just put anti-seize wherever it was locked up. Also put some on your studs.
rushw
Jul 18, 2015 01:46 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
