Sponsored by: CARiD
whining sound
Old Mar 19, 2008 | 05:58 PM
warren133's Avatar
whining sound
Hi i have a 87 toyota 4runner 22re and im getting a whining sound around the engine, i cant seem to narrow it down exactly but when i give it rpm it's pitch increases. The only thing i can think of is mabye a bearing, say water pump or cam shaft or crank shaft or seomthing, any ideas??
cheers
dave
Old Mar 19, 2008 | 06:05 PM
Kiroshu's Avatar
Power steering pump? Loose pully belts? Check your fluids?
Something my be just vibrating but check these things.
__________________________________________________ _
95 Toyota 4runner SR5 V6 3.0 4X4 Automatic 150,000 Miles
Old Mar 19, 2008 | 06:31 PM
4bows's Avatar
You didn't state whether the whine occurs out of gear or rolling, under power, in gear. If it only whines while in gear and rolling see if the whine goes away in 4th gear...if so refocus your attention to the tranny.
Old Mar 21, 2008 | 10:02 AM
warren133's Avatar
All the time, from the moment i start up, and i checked my fluids and they are fine, so im gonna try taking the belt off and checking each one individualy
Old Mar 21, 2008 | 11:16 AM
88Yota4runner's Avatar
dont turbos whistle? and dont the 87 engines have turbo? :3
Old Mar 21, 2008 | 12:17 PM
4Crawler's Avatar
Check the idler pulleys on the A/C and P/S belts (if present) and see if they are wearing out (will feel loose or gritty while turning). Easy test is to remove those belts and run the engine and check for the noise.
Old Mar 21, 2008 | 12:39 PM
soo is the turbo thing ruled out~?
zytra
Jan 24, 2019 03:16 PM
EVars
Sep 29, 2015 02:06 PM
irv
Sep 29, 2015 01:04 PM
voiddweller
Sep 28, 2015 11:21 PM
toyotasaurus
Sep 24, 2015 03:30 PM
