Sponsored by: CARiD
Rims
Old Feb 12, 2008 | 01:20 AM
JUNKER's Avatar
Rims
What Other Vehicles Rims Will Directly Bolt Onto My Five Lug 79 Toyota Pickup?
Old Feb 12, 2008 | 01:21 AM
JUNKER's Avatar
ANYBODY?
Old Feb 12, 2008 | 02:06 AM
b.miller123's Avatar
Do a search on here, you might not get much (because you are 2wd) but try anyways.
Other than that, go to a tire/wheel seller online. Type in your truck and find wheels for sale. That should be able to give you the layout (5 on 100mm or whatever it actually is). Then just start looking, or searching on the web to find vehicles that have the same lug pattern. Or head to the juckyard ready to start test fitting wheels.
Keep in mind though that there are other things to consider, like backspacing (or offset), and wheel width.
If I had to make a guess, I would say that any of the newer 5 lug toyota pickups (2wd) should fit, but this is an assumption and you know what the say about assumption
Old Feb 12, 2008 | 02:09 AM
oh, and welcome to yotatech!!!
and, "search" is your friend on here, and so are all the stickies, faq's and writeups, read up as much as you can on stuff before you post a question. I personally don't care, but others can get peeved, and will either ignore you (might already be happening.....) or they will just post "search" and leave
Old Feb 12, 2008 | 06:00 AM
dropzone's Avatar
Fossilized
ANYBODY?
Yotatech is a great source of info, but give it more than a minute between posts
I think that tire and wheel websites are a great source for stuff like this:
your bolt pattern is: 5 on 114.3mm which translates to 5x4.5". This website will give you ideas of alternate toyota rims that might fit
http://www.discountedwheelwarehouse...._Reference.cfm
Keep in mind that just because the bolt pattern might be the same, you might run into clearance issues with calipers/backspacing
5 on 4.5" is very common also to ford and jeep and I am sure some others
Old Feb 16, 2008 | 07:21 AM
Brenjen's Avatar
I'm in the same boat dude. I want to upgrade to 16" wheels on my '95 4Runner but it's tough to find information when you don't really know what terms to search for...I'm a 100% wheel & tire noob too. I just always looked at what was on my particular ride & put that size back on it or let the tire place decide.
People who spout "use the search function" should just refrain from posting at all unless they have some fetish they'd like to pass on to others about sifting through multiple millions of irrelevant pages of info to find a handful that aren't.
Basically if you don't know enough specifics of what to search for, then searching is of little use & just asking someone who knows (or claims to) saves a lot of hours of reading & wear on eyes that are already old & tired. I did eventually discover that my wheels are 15x7 stock & the 96's up to ? are 16x7 & should fit. Now to find some cheapo aftermarket 16's that fit the bill for me or some used ones that aren't warped.
chukarhunt
Dec 8, 2019 11:39 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
AkitaDog
Sep 3, 2015 09:01 PM
