Sponsored by: CARiD
3rd gen 4runner lift?
Old Mar 4, 2008 | 02:45 PM
czar's Avatar
ok so i have a 2000 4runner sr5 and i have heard that if you are to get a 2" lift in ter rear and a 3" in the front that it is supposed to level your 4runner, is this true, and what would it be like if i just did 3" all around, i mean would it look weird or something??
i was also wondering what your oppinion on the 3" ome lift is and what shocks to use with it, and what you think it should cost to have intalled, i am new to this and and do not want to get screwed on the cost, and can i just take it to any where that dose suspension?
Old Mar 5, 2008 | 12:03 AM
rocket's Avatar
I moved this to newbie section and renamed your thread title...your lucky It wasn't deleted instead.
"lift" can mean anything, please be a little more specific next time.
ok so i have a 2000 4runner sr5 and i have heard that if you are to get a 2" lift in the rear and a 3" in the front that it is supposed to level your 4runner, is this true, (no) and what would it be like if i just did 3" all around, i mean would it look weird or something?? (no)
i was also wondering what your oppinion on the 3" ome lift is and what shocks to use with it, ( http://www.wheelersoffroad.com/ome4runner.htm read the FAQ at http://www.sonoransteel.com/store_co..._liftkits.html Then consider "System 7.2" ) and what you think it should cost to have intalled, (it can vary and depends on where you go, can be $150 to $300+, you'll also need an alignment) i am new to this and and do not want to get screwed on the cost, and can i just take it to any where that dose suspension? (yes)
I would recommend that you spend a few days or weeks searching the threads HERE. There are thousands of posts about OME, Tundra springs, Bilsteins, Tokico, Sonoran Steel, etc. Theres also a few with tips on installing a lift yourself providing you have basic mechanical skills and the proper tools.
This section can be helpful too... https://www.yotatech.com/forums/f79/
Old Mar 5, 2008 | 10:43 AM
TRDPARTS4U's Avatar
FormerVendor
Here's the specs on the OME springs.
http://arbusa.com/USA-Vehicle-Applic...ta-4Runner.pdf
A lot of folks wanting as much lift as possible are using the 882 front springs, which are not on the chart. On my Tacoma I got right at 3" of lift on the front. I also used the OME shocks.
Thanks,
Gerone
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
