Sponsored by: CARiD
ABS question
Old Feb 28, 2008 | 05:27 PM
tman12345's Avatar
ABS question
so when i try to brake on snow the brakes basically won't push down unless i hit them again and it makes some noise, is that just the ABS, its a 95 4runner
Old Feb 28, 2008 | 06:05 PM
jason191918's Avatar
I would think that the brakes should go down the first time regardless. If the wheels are locking up at first, then the brakes make noise/the pedal shakes then yes that is the abs.
Old Dec 7, 2008 | 10:57 AM
mrjesen's Avatar
Having this same problem
Hi, was just searching the forums and found this, i have the same problem, little bit of wheel slip when braking on loose gravel on snow and the brakes bounce and the pedal does the whole abs thing but you cant push it back down and it just locks up. Scary at times. Is there a fix or can you disconnect the ABS all together cos its over rated anyway.
Marcus
JimiJams
Aug 7, 2015 01:36 PM
sqdg71
Aug 7, 2015 01:03 AM
makemusic116
Aug 2, 2015 05:23 PM
ty1er
Aug 1, 2015 11:53 PM
87turboPA
Jul 12, 2015 07:49 AM
