Sponsored by: CARiD
Axle Question
Old Feb 8, 2008 | 10:42 PM
DWEINBERG01's Avatar
Axle Question
So I installed my new front driveline, yeah. I put the 4runner on jack stands at all four tires. Started it up and put it in 4wheel drive to make sure the t-case was working. Driveshaft spun, centersection flange spun, front tires did not spin. Manual locking hubs were locked. Any ideas what went wrong. How much am I looking at to fix the problem?
By the way, 1995 4runner 3.0 v6 SAS w/ 1985 front axle.
Old Feb 9, 2008 | 06:59 AM
tc's Avatar
tc
Sounds like maybe the hubs didn't "catch" - try spinning the tire and see if the DS spins.
Old Feb 9, 2008 | 10:58 AM
Yoda's Avatar
Hub problem of some kind. Are they Aisin or aftermarket?
Old Feb 9, 2008 | 06:47 PM
They are aisin hubs. I will get it up on jack stands sometime next week and see if they catch. I'm hoping it's not a R&P issue or an axle issue.Thanks, I'll keep you guys up to date.
Old Feb 9, 2008 | 08:47 PM
tc's Avatar
tc
What kind of diff do you have? (locker, etc)
Old Feb 10, 2008 | 06:58 PM
As far as I can tell, it's is a standard offset pinion 4.88, no locker. I jacked up the front end this afternoon and locked the hubs. Spun the tires, but the driveshaft didn't spin.
Old Feb 10, 2008 | 07:55 PM
tc's Avatar
tc
Did you have both wheels off the ground? When you spun one, did the other spin backwards?
It sounds like you need to pull the manual hubs and check them out.
Old Feb 10, 2008 | 09:02 PM
When I spun one wheel, the other wheel didn't move. It stayed stationary. If I were to pull both of the hubs off to look at it, would the axles be in the locked position or unlocked?
Old Feb 11, 2008 | 10:55 AM
tc's Avatar
tc
Huh? Bummer this is in the no flaming Newbie tech section, cuz I would LOVE to have some choice words about how you need a solid axle ...
Anyways, the axles don't change "positions" - the manual hub either engages the splines on the axle, thereby connecting it to the brake rotor/hub/wheel, or not.
You can isolate if it's the manual hub by taking it off and turning the AXLE by hand and seeing if the other wheel and/or driveshaft move.
Did you rebuild the hubs? If you get too much grease in there, they won't work right.
Old Feb 11, 2008 | 11:03 AM
AxleIke's Avatar
This also sounds like it could be classic broken Birf syndrome.
If it was your diff, you'd likely hear it. Only thing you might not hear is a busted pinion. That could be checked by seeing how much wiggle you have at the DS flange.
But if it isn't your hubs, yank the birfs out and check them.
Old Feb 11, 2008 | 12:16 PM
sh0kk86's Avatar
takes 5 minutes to pull the locking mechanism on the hubs to figure out where the problem lies. use the fsm to assmeble the hubs back properly, then see if the problem persists.
if so its deeper in the axle, then pull the whole hub
Old Feb 11, 2008 | 04:00 PM
TORTIS's Avatar
my manual hubs were so bad when i bought my 4Runner, the cog would not rotate out to engage. after a through cleaning and greasing, i had 4 wheel drive. hopefully it is something as simple as cleaning your hubs.
Old Feb 11, 2008 | 06:18 PM
TC: It is already solid axle. I am just new and dont really know where to start.
I do have to reseal the axles so I will definintley going through everything. I am going to pull the hubs tommorrow to check those out. Then the tear down begins. If it is a broken birf, I will probably get the longfield axle/birf combo and use my current ones as spares.
I have the fsm pages printed and also the rebuild thread from ih8mud.com.
Thanks for your help guys, really appreciate it.
Old Feb 11, 2008 | 06:53 PM
AxleIke's Avatar
TC's joke was about the fact that you already have a SAS. I'm pretty sure its a pet peeve. I know its one of mine.
Sounds like you've got a good handle on the repair. Start from the outside and work inward. You'll get it.
Old Feb 11, 2008 | 07:01 PM
notanymore's Avatar
i think TC was eluding that SASs arnt all everybody makes them out to be. but hubs would be my first guess as to what it is.
Old Feb 11, 2008 | 08:03 PM
Oh, okay. I get it. Sorry bout that TC. Been a long week.
Old Feb 11, 2008 | 08:38 PM
tc's Avatar
tc
It was a perhaps too subtle jab that you need to learn quick - these things happen A LOT to SFA rigs. The maintenance on a SFA is at least 10x more frequent and more involved than IFS.
You gotta remember that you're giving up 10 - 20 yrs of design advancement and warranty/maintenance-reduction focus going from IFS back to SFA...
Old Feb 13, 2008 | 03:43 PM
I pulled the cover off of the hubs yesterday. On the driverside, just from looking at it, I noticed that I was missing the bolt that goes into the birfield. On the passenger side, I am missing the big spring and the bolt, so I am guessing, based on mu luck, that I am missing more parts farther back in the hub.
Does anyone know where I can get any missing parts other than the dealership.
Also, what is the best way to get the cone washers out. I have heard a brass drift and a hammer, but is that a real hammer or a rubber mallet or what?
Old Feb 13, 2008 | 03:54 PM
881stGenRunner's Avatar
regular hammer works just fine. also try using a flat head to try and pry it out while tapping it with the hammer
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
