Sponsored by: CARiD
ignition
Old Mar 26, 2008 | 12:29 PM
yoder519's Avatar
ignition
a while back when i tried to start my yoder when i turned the key it just clicked. it didnt crank or anything. now it started doin it every once in a while. itll do it then ill crank it again and shell fire right up. do any of yall have any idea what it could be? today i tried to start it and it took me forever to get it cranked.
Old Mar 26, 2008 | 12:51 PM
rdlsz24's Avatar
Contacts in your starter are worn:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Rob
Old Mar 27, 2008 | 07:06 PM
bigarms23's Avatar
you might look into a msd ignition system i have one and i like it
Old Mar 28, 2008 | 09:00 AM
Psalm 112's Avatar
can you describe it a little further...are you referring to the actual ignition, is the key turning, etc?
Old Mar 31, 2008 | 11:50 AM
yoder519's Avatar
well it hasnt donme it anymore but when it did i turned the key all the way and it just clicked. so then i kept turning it fast and it cranked right up
Old Apr 1, 2008 | 07:22 AM
Psalm 112's Avatar
I had an issue several weeks ago, that sounds similar to yours. The key would turn only a few positions, but not all the way to start. When I called some local shops they all told me it was the starter. Obviously it wasn't the starter, since it (the ingition) wasn't turning that far. I ended up calling a friend of mine who is a locksmith. It ended up being some worn-out tumblers in the lock/ignition. They were removed and she fires right up now.
Old Apr 1, 2008 | 06:04 PM
yoder519's Avatar
well my key turns all the way but it just clicks then after you keep turnin it it cranks up.. it happened again today it did it once then it started but it hesitated i guess youd call it
Old Apr 1, 2008 | 06:46 PM
rowdy235's Avatar
no, rdlsz24 called it, you have starter problems. Most likely the starter contacts. Have a look on 4crawlers page, he has a write-up on replacing them.
Old May 11, 2008 | 04:19 AM
backwoods_bently's Avatar
probably could also check your grounds. i think there are 3 of them total. i had that same problem with mine a few years back and it was the ground. i followed the ground wires to found 2 were loose and corroded. i would turn the key and it would just click once and wouldnt do nothin, then i would keep tryin it till it would eventually start. i would definately check it out, if thats the case its free to fix.
Old May 11, 2008 | 09:32 AM
yoder519's Avatar
thats exactly what mines doin i hVE TO KEEP TURNN IT TIL IT CRANKS
Kamaloha
Oct 16, 2015 05:13 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
JHalcyonM
Sep 14, 2015 01:10 AM
