Sponsored by: CARiD
lockout hub problems?
Old Jul 19, 2013 | 11:04 PM
toyota gray's Avatar
My 86 Toyota pickup 4x4 has always went into 4x4 good but this past winter it stopped working I can lock he hubs put it on 4 wheel drive and the Axels are turning but not the tires any suggestions on what's wrong? Thanks.
Old Jul 20, 2013 | 12:17 AM
wyoming9's Avatar
Red face
Well one or both of your hubs is not locked in could be something simple or major carnage
Old Jul 20, 2013 | 07:18 AM
thefishguy77's Avatar
Pull your hubs apart. Really easy to do. Just go through them don't loose the small parts when you take them apart. There is a little ball bearing where the turn dial mates with the hub itself. Probable the most commonly lost part on them. Just make sure you do have junk in there or a broken spring. There are 2 springs in there both of those could cause the gears to not mesh. A quick search turned up this and it's better than mine so I hope this link helps.
https://www.yotatech.com/forums/show...353&styleid=51
Old Jul 20, 2013 | 07:21 AM
Just follow the link and part way down there is a PDF link. That will give you a good exploded view.
Old Jul 20, 2013 | 12:34 PM
Thanks I'll let you kW how it goes
Old Jul 24, 2013 | 08:17 PM
Hey it was the springs I fixed it cleaned it up and it works good thanks for the help
Old Jul 25, 2013 | 12:02 PM
Anytime.
glowz825
Jan 25, 2022 09:28 AM
oldirtydirt
Feb 23, 2020 09:30 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
