Sponsored by: CARiD
22re running rough
Old Jun 13, 2013 | 03:25 AM
dbond253's Avatar
22re running rough
So I just replaced my head gasket, timing chain, desmogged, (I don't need emissions) distributor, plugs, wires, coil, and afm. I also have adjusted my valves and my tps not all at once. but after I got everything back together it ran like crap and each thing I replaced made it run better. I also installed a pacesetter header. I adjusted my tps yesterday and that was a big improvement but I still have a slight studder when excelerating, I have a brand new fuel filter in, I searched around and between pirate and here got lots of tips and had some good pointers from some of the guys here. My project for today is going to be checking the fuel pressure but if anyone has any suggestions I would appretiate it. From what I have been reading it could possibly be o2 sensor related? I know its a long post but I want to get this issue worked out and get wheeling again I have a 1992 p/u 22re 32x11.5 with 4.56 gears I'm sure there are typos I just got off work and am not going to bother fixing them thanks in advance
Old Jun 13, 2013 | 02:39 PM
dbond253's Avatar
It also shakes a lot at idle
Old Jun 13, 2013 | 02:41 PM
Discombobulated's Avatar
What kind of o2 sensor did you or PO put in??
Old Jun 13, 2013 | 03:38 PM
dbond253's Avatar
I'm pretty sure its the original o2 sensor
Old Jun 15, 2013 | 10:05 PM
Wheels43's Avatar
EGR plugged?
Disconnect the egr vacuum line and see if it smooths out. It fixed my 22re before I pulled it out to do a 3.4L swap.
Old Jun 17, 2013 | 09:02 PM
thefishguy77's Avatar
I am assuming your CEL is on have you checked what codes are throwing. That will help keep you from replacing stuff that might not be broken.
You might have said that, it was a long post. If so disregard, if not let us know what codes
Old Jun 17, 2013 | 11:05 PM
dbond253's Avatar
Wheels 43 I removed my egr system but I know what your saying it can get stuck open and run rough
Thefishguy77 My CEL is not on I tried checking the codes but I'm a little confused on how my haynes manuel said there is a plug by the ignition coil which there isn't but I read on here that you put a jumper to the same connectoers as you would to set the timing which I tried and all I got was a steady continious flashing of the CEL with the key on... Thanks for the suggestions/help
Old Jun 18, 2013 | 05:07 AM
Check fuel pressure also it wouldn't hurt to do another fuel filter just to see if this new one is clogged already. I so you might have bad sediment build up in your tank. Just kinda guessing but fuel pressure is probably the next best thing to check. Also log shot but how dirty was your intake plenum when you took your egr off. Of you tried to clean it, it's possible that you have carbon loose in there interfering with your fuel delivery. Still just guessing.
Old Jun 18, 2013 | 11:01 AM
dbond253's Avatar
I put a new O2 sensor in and its running like normal idles high but it always has
Old Jun 23, 2013 | 08:01 AM
Easy fix. Keep us posted if this doesn't work. But nice work
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
