Sponsored by: CARiD
91 toyota p/u fuel pump troubles
Old Aug 1, 2013 | 12:18 AM
poundh's Avatar
Not getting any power to the pump and it is new.
Old Aug 1, 2013 | 02:26 AM
Jasper 83's Avatar
Somebody correct me if Im wrong but doesnt the fuel pump get the signal to come on from the airflow meter on top of the airbox. Somebody can probably provide a link to the fsm but you should be able to troubleshoot the problem with that.
Old Aug 1, 2013 | 07:07 AM
poundh's Avatar
Is there a way to just wire pump up with a switch and would it work if I did.
Old Aug 1, 2013 | 08:19 AM
Scirocco16v's Avatar
yes, after bringing mine back from the dead, I had a switched fuel pump for about a week till i could sort out other issues.
I traced the FP hot back into the cab under the passenger seat where the wires exit under the truck and taped in there with a hot lead & a switch.
Old Aug 1, 2013 | 12:25 PM
poundh's Avatar
Thanks
Old Aug 1, 2013 | 12:38 PM
Thanks
I have an `89..will look at it when I get home and ID the wire for you if it helps
Old Aug 1, 2013 | 03:13 PM
On my 89 the wire was blue with black stripe and brown dots
puffin04
Jul 10, 2015 09:17 PM
OffroadRalph
Jul 2, 2015 07:28 PM
87blyota
Jul 1, 2015 05:26 PM
kazuya2416
Jun 27, 2015 12:24 PM
Dennis140
Jun 17, 2015 10:37 AM
