Sponsored by: CARiD
Not getting fuel
Old Aug 25, 2013 | 12:31 PM
dbell's Avatar
Not getting fuel
So I just bought a 91 4x4 with 22re and was able to drive it for only a day and a half. It ran like a champ. I checked my oil and it was low so I filled it up and now it wont start. I checked for spark and it looked good. Sprayed a little starting fluid in it and it fired up and died. That told me no fuel. Couldn't hear pump so I installed new pump and still nothing. I tried the relay bypass in the diagnostics box and still no pump. Hook pump straight to battery works fine but still wont run. I need to be back on the road again so does anyone have any ideas?
Old Aug 25, 2013 | 01:02 PM
Yotafreak81's Avatar
Clogged fuel filter maybe.....that would be my next step personally.
Old Aug 25, 2013 | 01:26 PM
EFI fuses? I would still check the fuel filter. Is it a pick up or 4 runner?
Old Aug 25, 2013 | 01:30 PM
dbell's Avatar
I forgot to mention I already changed that. I am getting fuel to that point for sure when I hook the pump straight to the battery.
Old Aug 25, 2013 | 01:35 PM
dbell's Avatar
Its a pickup and I checked the EFI fuses and the open circuit relay and the main relay. I also propped open the air flow flap thing so that it would tell the fuel pump to work but still nothing. Im lost.
Old Aug 25, 2013 | 03:10 PM
https://www.yotatech.com/forums/f127...-relay-183654/
check the very bottom picture in this thread, this might help, might not, I myself am still a somewhat of a newbie, so I feel your pain when it comes to not having a running yota and get stuck. I will keep searching for ya and hopefully help you get this figured out.
Old Aug 25, 2013 | 03:14 PM
If there is a higher authority on the EFI fuses/relay and fuel pump problems feel free to chime in. Thanks.
Old Aug 25, 2013 | 08:25 PM
dbell's Avatar
Thanks yotafreak81. I will have to open my relay up and see if that's my problem. I appreciate the info. I will let you know if that fixes my problem.
Old Aug 27, 2013 | 06:29 PM
dbell's Avatar
Update on my problems. I called the Toyota dealership service tech and told him my situation. He said if will start with starting fluid then I could rule out any relays. He said to start checking the wiring harnesses around the ECU and under the passenger seat. Come to find out I don't have power in the wiring harnesses. Just need to trace down where I am losing power.
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
