Sponsored by: CARiD
02 Tundra overheating
Old Jun 25, 2013 | 04:39 PM
aznativemike's Avatar
I have an 02 Tundra, 4.7 4x4 that will redline 15-20 minutes after starting it. So far I've replaced the radiator and t-stat, the hoses are still good and the water pump is less than 2 years old. No sign of blown headgaskets either. Any thoughts on this?
Sent from my SGH-T699 using Yotatech
Old Jun 25, 2013 | 04:43 PM
rworegon's Avatar
What is the ambient temperature and how is it being driven at that 15-20 minute mark?
Fan clutch working properly?
Old Jun 25, 2013 | 05:15 PM
Swimmerboy2112's Avatar
Check the fan clutch.
Old Jun 25, 2013 | 05:26 PM
Fan clutch seems ok, proper resistance when you spin it. After replacing everything I just sat it at idle in the garage, once it reaches operating temperature it steadily and relatively climbs toward the red line after.
Old Jun 25, 2013 | 05:27 PM
Any other way to determine if fan clutch is bad?
Old Jun 25, 2013 | 05:37 PM
toyota4x4907's Avatar
Just throwing this out there.... The sending unit or -something- on my '00 4.7 is broken. As soon as the t-stat opens, the needle jumps to "OVERHEAT"/redline. I know it is NOT overheating as I have been driving it like this for almost 2 years now .
Possibly your sending unit or sensor or something is problematic and once it detects a slight increase in temp, it just goes.
What signs have you looked at for the possibility of a bad head gasket?
Have you replaced the radiator cap?
Old Jun 25, 2013 | 05:46 PM
I didn't replace the cap (for some reason). As far as the head gasket I haven't seen any oil and coolant mixing anywhere and no white smoke blowing out. I didn't put a test on it but that's just my guess.
The CTS and/or sending unit crossed my mind. I bought the truck from my dad, he took meticulous care of it over the years (has 230k miles) but I wouldn't be shocked if the newer pump is a reman, which some can have issues
Old Jun 25, 2013 | 07:08 PM
A couple years ago when the HG on my 22re went kaput, the only symptom I got was coolant being pushed out of the overflow reservoir once you shut it off. No mixing of the fluids, MAYBE white smoke, but it was still decently cold here, so I was getting condensation plumes anyhow.
Why not buy a fan clutch, then return it if its not the problem. Or keep it just to replace it since it probably has 230K miles on it.
But all this happened after you replaced all those parts? Have you tried driving it? Once you get up to speed the fan isnt doing much work.
Old Jun 25, 2013 | 07:13 PM
It overheated before replacing the parts, the radiator definitely needed replacing, it was seeping out in different places, just strange with all the new parts that it's still doing it. I could try a fan clutch I guess....I'm curious about those sensors, think that's a realistic possibility?
Old Jun 25, 2013 | 07:19 PM
I would try the fan clutch and rad cap since it was doing it before the new parts.
Old Jun 25, 2013 | 07:45 PM
Thanks much! I'll give that a shot!
Old Jun 25, 2013 | 08:59 PM
Also noteworthy, even as the guage approaches the redline, the air coming out of the vents isn't hot. I already bypassed the heater core once and that it still overheated
Old Jun 26, 2013 | 01:11 AM
Hmm no hot air from the vents, maybe you have an air bubble stuck in the cooling system somewhere. Have you tried "burping" the system?
Old Jun 26, 2013 | 05:53 AM
It had appeared as though we got all the air out but I can't say 100% that I did
ladybugRC
458
Aug 21, 2020 10:41 AM
ToyotaMD
Nov 9, 2015 11:53 AM
LCE_Performance
Oct 1, 2015 01:03 PM
beltcutter
Sep 30, 2015 06:14 AM
4runnerFireman
Sep 29, 2015 06:24 AM
