Sponsored by: CARiD
stripped spindle??
Old Aug 1, 2013 | 09:48 AM
hunterh17's Avatar
stripped spindle??
I am in the process of changing outer wheel bearing. I ordered all newadjustment nuts claw washer and lock washer but the adjustment nuts will not screw back onto the spindle at all. Think spindle is stripped?
Old Aug 1, 2013 | 09:50 AM
rokblok's Avatar
Have to see it to know for sure. Pics would help. Also helps to know what we are working on...
But I've always easily nutted my spindle. Has to be just perfect....then presto...magic.
Old Aug 1, 2013 | 09:51 AM
gigatech88's Avatar
Pictures? ?? Check the threads, carefully clean them up with a file if necessary.
Old Aug 1, 2013 | 10:32 AM
wyoming9's Avatar
Red face
They have to be lined up just perfect.
Sometimes flipping them 180 degrees will get them started
Old Aug 1, 2013 | 02:32 PM
hunterh17's Avatar
sorry its a 95 t100 dx 4wd. I will try to get pics later but its like the nut wont even start on it, either the top part of the nut will be on and not the bottom or vice versa and when I turn it it just pops off. the factory ones were complety striped inside the the nut so bought new ones from Toyota and cant get them on either I just feel like im going to end up stripping them out too. I just cant imagine it would be this hard to screw a nut back on but maybe theres a trick to It I don't know or its just stripped. and apparently you can get tht piece, Toyota said I have to buy that whole knuckle assembly with that part on it?
Old Aug 1, 2013 | 02:35 PM
hunterh17's Avatar
what do you mean flip them? ive tried to get both of them to screw on flipped em around and every which way and cannot get it to go on
Old Aug 1, 2013 | 03:05 PM
gigatech88's Avatar
If the factory ones were stripped then your spindle threads are probably screwed up. Someone may have tried to gun then on with an impact. How hard was it to take the old ones off??
Old Aug 1, 2013 | 03:14 PM
hunterh17's Avatar
It was hard as hell to get the inner nut off I had to use a breaker bar with a Cheater to get it off
Old Aug 1, 2013 | 03:18 PM
gigatech88's Avatar
Inner nut? ?? You mean the nut behind the crown washer (whatever it's called )
Old Aug 1, 2013 | 03:54 PM
hunterh17's Avatar
Yeah that one
Old Aug 1, 2013 | 03:59 PM
gigatech88's Avatar
Ok. If you can chase the threads and make it work go for it. Tedious, especially if you don't have a tap and die set . Otherwise buy new spindles
Old Aug 1, 2013 | 05:01 PM
hunterh17's Avatar
When i put the hub assembly with the bearings back on all the way back it has so much play but when it pull it forward its tight. That doesn't make sense bcus when the wheel is on it will be loose and the rear seal won't be closed and grease going everywhere
Old Aug 1, 2013 | 05:03 PM
gigatech88's Avatar
With pictures I can tell ya what's going on. Did you set the preload correctly? ??
Wait. . If you can't get the nut on you can't. Never mind. . Pictures
Old Aug 1, 2013 | 05:12 PM
hunterh17's Avatar
Ill take some pics tomorow morning. I just thought it was odd that its tight when pulled out s little but when the hub and rotor are pushed all the way back its extremely loose.
Old Aug 1, 2013 | 07:10 PM
arlindsay1992's Avatar
It shouldn't move at all along the axis of the spindle. It should obviously rotate though. If the spindle threads are damaged you'll likely need to replace the spindle. Grab one from a junkyard. Don't drive it until it is fixed. You don't want a wheel coming off.
some drunk guy
Aug 3, 2021 06:09 PM
G-off
Dec 29, 2015 12:44 PM
stanz
Oct 30, 2015 10:33 AM
ToyotaMD
Sep 22, 2015 06:28 AM
1965chevy
Sep 20, 2015 07:33 PM
