Sponsored by: CARiD
battery draining problem
Old Aug 20, 2013 | 12:41 PM
JDUBYOTA's Avatar
So i had a new 22r put in my 84 pick up! and ever since then ive had electrical problems, i put a new fuse box under the hood cause the old one melted and i still am getting drains! any ideas on what it could be?
Thanks,
Jake
Old Aug 21, 2013 | 12:03 PM
swampfox's Avatar
You can make a tester out of a 12v buzzer, just put some wire leads on it. What you do is hook it between the 12v battery post and the cable clamp after you unhook the cable. The buzzer will sound if there is a short because the short is a ground .once it starts buzzing pull one fuse at a time and listen for a change ,That will be the circuit to check. If it is a cd player or something else running it may not buzz. This can also be done with a test light.
Old Aug 21, 2013 | 01:10 PM
wyoming9's Avatar
Red face
Perhaps explain just how the fuse block got melted ??
That might give us an idea just where the problem might lie.
So your battery drains flat over night or in a longer period of time??
Then you put the battery on a charger to be sure it is fully charged??
Have you checked that the battery is still good ??
That all the battery terminals cables connections are good ??
I have seen poor ground cables cause a battery drain
kcaudill
Jul 20, 2015 12:06 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
ryerye13
Jul 14, 2015 08:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
colinmil
Jul 6, 2015 04:03 PM
