Sponsored by: CARiD
Power to the Dist?
Old Jun 25, 2013 | 12:49 PM
bolard's Avatar
Power to the Dist?
Should there be voltage going to the the dist. when the key is in the on postion on a 93 3.0, I have searched the for info on past threads & post but no luck, Any info would help, Thanks
Old Jun 25, 2013 | 02:11 PM
brianh699's Avatar
No the ECM won't tell the ignitor to send current to the ignition coil until it senses rotation from the pickup coil in the dist. http://personal.utulsa.edu/~nathan-b.../9systemci.pdf The positive terminal on the ignition coil should have battery voltage with key on. http://personal.utulsa.edu/~nathan-b...12onvehicl.pdf
Old Jun 25, 2013 | 06:24 PM
Punchy's Avatar
Also the Coil, Dist, AFM Injecters and TPS all use the same B+, There all spliced together with fuseble links.
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
