Sponsored by: CARiD
4runner butt sag...
Old Jul 22, 2009 | 06:02 AM
toyolove's Avatar
4runner butt sag...
Hey all, so I have an 87 4runner that I'm going to be usuing for a new job. Thus I will be cramming a box and tools into the back of my truck. And possibly a few speakers from my dad's suburb (2 15's ) so I was wonduring if I should replace the rear leaf cause its pretty much flat and I don't know if it can handle the extra weight. I'm thinking it will be around 300 lbs daily. Thanks!!!
Old Jul 22, 2009 | 06:10 AM
snobdds's Avatar
Search first! There are plenty of better options then replacement OEM leaf springs.
Old Jul 22, 2009 | 06:13 AM
Squiddy's Avatar
Given the age, the fact that it is a 4runner, and the sag, you almost certainly need new springs, not to mention shocks. Spring sag/wear out is a well known issue here. The weight is not so much of an issue (at that amount anyhow). There are many threads here on the topic. You can basically get stock type replacements (less good given 4runner sag pretty much at baseline) or aftermarket type solution (better shocks and springs). Would recommend the latter, tho more expensive...tho again many threads here on how to do it [somewhat] cheaply
Old Jul 22, 2009 | 06:16 AM
toyolove's Avatar
Sweet thanks. Guess I'm making this priority now. I don't want to find out what could happen if I don't replace them.... Thanks!
Old Jul 25, 2009 | 04:12 PM
Rusty Boots's Avatar
I am in the same boat as you. There are many options:
1. OEM replacements (JC Whitney)
2. Aftermarket (OME, Downey, Alcan, etc.)
3. Add a leaf kits (Long thin leaf for a softer ride I think?)
4. Zuk mod
5. 63" Chevy springs, Ford F-150 springs (57")
Search any one of these options...good luck!
Old Jul 25, 2009 | 04:48 PM
toyolove's Avatar
Sweeet!!! Sounds good man
Old Aug 20, 2009 | 04:42 PM
88Cleve4runner's Avatar
the Zuk mod i hear is a good idea if you don't off road too much. it give a little umph to the rear and makes a real nice ride... so i've read. the only experience i have are with the 63' chevy's and i love them.
Old Aug 20, 2009 | 09:38 PM
desertcamper67's Avatar
And the cheapest fix......Air shocks. Fully adjustable height as needed (within a few of inches)
I don't suggest this is a great or even good mod, but it works and is cheap.
Not recommended for wheeling. They aren't built for that kind of abuse. 300lbs is no problem though.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
