Sponsored by: CARiD
Put New clutch in my 85 toyo somthing WAY wrong!
Old Aug 9, 2009 | 04:06 PM
Creek's Avatar
OK hey y'all pleased to be here i hope some one can help me....I had a mechanic i found on (craigs) put in new motor..I decided to put in new clutch as well...Ok every thing goes in..Motor sounds good..(carb toast another story)...When truck is idling it will not shift?...When i turn ignition off...It shifts fine??...Line was bled by mechanic..But he has since fled..Now i have a truck i can not drive...Any ideas on my clutch dilemma??...I would love to know..Thank you..Creek
Old Aug 9, 2009 | 04:14 PM
Travisfab's Avatar
What do you mean by shifting? Are you saying it wont go into gear?
Old Aug 9, 2009 | 04:19 PM
Creek's Avatar
It will shift but i had to realy force it and jam it in first...and was lucky to get it into reverse to get in driveway...grinding noises...And when truck is off...s into gears like butter
Old Aug 9, 2009 | 04:29 PM
Creek's Avatar
The guy that put it in said it may be the slave cylinder?...As he did bleed the line and that did not do anything?
Old Aug 24, 2009 | 11:48 PM
TechWrench's Avatar
It could be problem with slave cylinder, or adjustment. Also could be problem with pilot bushing/bearing for input shaft in rear of crankshaft.
Old Aug 26, 2009 | 12:19 AM
wyoming9's Avatar
Red face
Hi Creek welcome!!
Be nice to know where you live .
Did you get this truck and never did drive it till the new engine and clutch were installed??
Do you have someone who can push the clutch pedal while you watch if you have full range of movement on the slave cylinder .
Possible problems that are easy fixes .
Clutch still needs some more bleeding.
The rod on the Master cylinder needs adjusted.
Could be a bad or wrong slave cylinder..
For the rest of the problems you will be pulling the transmission out .
Forgot to install the throw out bearing or have it in backwards .
Wrong clutch in correct box
transmission is just shot but will go in gear with engine off just fine because nothing is moving
I do wish you well and hope it is simple.
Old Aug 29, 2009 | 10:30 AM
Creek's Avatar
Still Buming out on truck
Hello all,...I am still unable to drive truck...do to funds,,I was not able to take to shop...I did have a guy come over and bleed the new slave i put in...Only way i can get the truck to shift is to pump hard between shifts(any gear)....Could this be because he did not have a vacume when he bled it?...Any tips?...Thank you!
Old Aug 29, 2009 | 12:29 PM
myyota's Avatar
I would recomend that you alse replace the clutch master cylinder, they can go bad and not apply enought presure to the slave cylinder, and it would also be a good idea to replace the shifter seat and bushing. I had to do all of these on my 86 4Runner and now it shifts very smooth.
Old Aug 29, 2009 | 03:48 PM
Creek's Avatar
Thank you myyota.You are probably right...as everything else seemed to have gone out..I am hoping that will get my truck up and running.
Old Aug 29, 2009 | 04:03 PM
Creek's Avatar
And yes wyoming9...I did drive the truck..purchased it cheap...Had front end dif redone drove it a few times..then the engine blew..I have put quite abit into it and hope i do not have to put way to much more into it..But i love these trucks so i am gonna stick to it.
Old Aug 29, 2009 | 04:26 PM
myyota's Avatar
Considering the age of our trucks and that alot of people don`t take care of them as well as they should, when you buy it sometimes you end up buying all the problems it has from lack of maintenance, but once you get all of the problems fixed you will have a truck thats very reliable and will still be on the road for many more miles and years to come, so don`t give up on it.
BushPig
Oct 29, 2022 06:26 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
