Sponsored by: CARiD
rear end trouble
Old Aug 21, 2009 | 07:19 PM
jojapro's Avatar
rear end trouble
jacked up truck checked both tires absolutely no play there, not he wheel bearings. I rotated the tire when it was jacked up and noticed some play in the driveline when rotating forward to reverse. seems to be comming from the differential. Also notice the drive shaft was rotating slightly oblong from the carrier bearring to the rear dif. but there is no play in the u-joint. This is causing a slight vibration at higher speeds. Could this be caused by impropper load on the pinion bearing/ shaft? or do i need to replace some parts in the rear?
Old Aug 21, 2009 | 09:44 PM
myyota's Avatar
It could be anything from improper preload on the pinion bearing to a bad pinion bearing. Also check the u-joints, when they go bad they can cause vibrations
Old Aug 21, 2009 | 11:48 PM
2DoorRunner's Avatar
I think you need more fiber.
Old Aug 22, 2009 | 07:30 AM
jojapro's Avatar
more fiber?
Old Aug 22, 2009 | 09:30 AM
desertcamper67's Avatar
It helps with irregularity in the rear end.
Old Aug 22, 2009 | 09:45 AM
jojapro's Avatar
ha ha! Ill give that a try, thanks.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
