Sponsored by: CARiD
1989 Toyota Truck Leaking frenzie!!
Old Jul 30, 2009 | 11:19 AM
jgcalifornia's Avatar
Just tryin to get some input on any possible options, other than what I know I eventually have to do....Budget does not allow to replace, so anyone that can take a peek at my truck photos & offer their two cents, Id really appreciate it!
thank you!
http://s91.photobucket.com/albums/k3...view=slideshow
Old Jul 30, 2009 | 12:47 PM
83's Avatar
83
Hard to tell anything from those photos. Learn how to post a photo on the site, around 800x600 fits nicely, and give us some more info.
Old Jul 30, 2009 | 12:59 PM
Lumpy's Avatar
I know what those parts are but what are we suppose to be looking at. The only difference between yours and mine are that most of what you have is shiny...
so the tranny and or t-case leaks a bit. Add fresh oil and check it every now and then.
Old Jul 30, 2009 | 03:50 PM
kiyobrown's Avatar
Yeah dude, I am still tracking down all the leaks in mine. I found the transfer case leak, gonna find the transmission leak so I can go order a couple gaskets. Check your fluids and keep running that thing down the road, just like everyone else.
Old Jul 30, 2009 | 04:00 PM
so the leaks you found in your transfer case, the fix is a gasket? Did you have to take the entire thing apart?
Check the fluid all the time, I was hoping to get some advice on any temporary repair/solution for the leaks, so Im not leaving puddles of fluid everywhere I go, until the cash comes along to do it properly.
thanks for the reply!
Old Jul 30, 2009 | 04:09 PM
Lumpy's Avatar
Well it looks as if someone used a liquid gasket of some sort on yours, it may have found a week spot or the oil could be eating at it.
If it's too bad then yes you will have to drop the t-case and replace the gaskets with the correct ones. May as well drop the trany and do the clutch while your in there if you have a ton of miles on it. It's not hard but a real PITA to do that's all. I have not had the t-case off yet (soon though) but I know of people who have.
May also be the rear main leaking as well or the trans leaking into the bell housing. The one picture looks as if the drain plug maybe leaking.
Old Jul 30, 2009 | 09:30 PM
kiyobrown's Avatar
yeah mine looks like a rear output seal behind my companion flange thats leaking. Mine doesn't leave puddles on the ground, so yours sounds a little more serious. If you can track em down and fix it yourself, you could save alot of money. Some seals don't require dropping the case, others do. Just be sure you got the right source of the leak or you will just keep chasing it around. I have degreased mine and drove it around a couple times to narrow it down. Good Luck!
Old Aug 2, 2009 | 10:51 AM
"May also be the rear main leaking as well or the trans leaking into the bell housing. The one picture looks as if the drain plug maybe leaking."
There is most definatly the rear main seal leak.. Liquid gasket? Would they have just put it around the seams?? I also noticed some of the leaks are coming out of the bolts, went to tighten them a bit, they seemed pretty tight...
Old Aug 2, 2009 | 10:53 AM
"If you can track em down and fix it yourself, you could save alot of money. Some seals don't require dropping the case, others do. Just be sure you got the right source of the leak or you will just keep chasing it around."
ya, thats why its all shiny, to find the source, and so far i found 3, but though the tranny had to come out..so i can replace some of them without having to do that??
thanks for the reply!!!
matrad
Aug 26, 2024 08:21 AM
voiddweller
19
May 2, 2016 09:10 PM
GorgeRunner
Jun 27, 2015 07:01 AM
paxanders
Jun 21, 2015 06:29 AM
Krash
10
Jul 13, 2002 09:21 PM
