Sponsored by: CARiD
URGENT and need the help...
Old Jul 24, 2009 | 02:43 PM
86TOYO's Avatar
I have a 86 pickup and i took the calipurs off to replace brake pads. yet i cant get the brakes to bleed and iv tryed to look for posts about this but everything iv found talks about the rear cylinders and how u should replace them...iv done the pump methods, and she just wont bleed.. i didnt touch the rears at all so it shouldnt have anything to do with them...? any sugestions would help thanxx.
Old Jul 24, 2009 | 02:44 PM
86TOYO's Avatar
by the way the brakes worked before i did the pads
Old Jul 25, 2009 | 07:20 PM
Sprag-O's Avatar
First... why you disconnect the calipers to change pads?
And your rear lines should be isolated... but you should still bleed the rear pass. side first, the rear driver, front pass. then front driver... you need to try and cycle all the air out of the lines.
Old Jul 25, 2009 | 07:25 PM
tc's Avatar
tc
The front/rear isolation isn't as bulletproof as it should be. The LSPV ties the two systems together. Bleed the LSPV after the rear brakes, then bleed the fronts. Make sure you don't run the master cylinder dry in the process - cuz then you'll have to bleed that too.
Old Jul 25, 2009 | 10:41 PM
myyota's Avatar
Make sure the bleeder screws arn`t plugged with dirt, that would keep the brakes from bleeding.
Flossy
Aug 5, 2015 05:14 PM
bkilz
Jan 30, 2005 12:14 PM
wvuviv30
19
Sep 9, 2004 04:52 PM
