Sponsored by: CARiD
lets talk more power cheap
Old Aug 4, 2009 | 02:11 PM
hiclearance's Avatar
so im a 22re guy im on my 3rd motor.im not a fan of the big motor swaps. whos done some cheap easy bolt ons or stock mods to increase power? i got a fresh motor 7k i added the rv cam and thorley header with 2.5 flowmaster exhaust.
Old Aug 4, 2009 | 02:52 PM
Aenema's Avatar
22RE's arent big powerhouses, but try a new air intake? should add a few hp.
Old Aug 4, 2009 | 02:53 PM
scuba's Avatar
Alright let's talk :
USE THE SEARCH BUTTON
Old Aug 4, 2009 | 03:01 PM
Fink's Avatar
Moved to Newbie Tech Section.
As scuba so gracefully said, please try and search.
We get at least 10-15 of these types of threads each month.
I also renamed you're thread title given it was fairly ambiguous.
Might be a good idea to review the Rules also.
Let us know if you can't find an answer.
Fink
Old Aug 4, 2009 | 03:24 PM
BigBluePile's Avatar
Put a supercharger and a hiflow seach engine in it...
Old Aug 5, 2009 | 09:11 AM
funny jokes search engine didnt work thanks tho
Old Aug 5, 2009 | 09:15 AM
scuba's Avatar
The search engine didnt work when you searched for 22RE Power Mods..?
Yeah, Right.
There's a buttload of threads on this subject.
Old Aug 5, 2009 | 09:16 AM
must have been my comp it redirected me, try again later
Old Aug 5, 2009 | 09:17 AM
Hmmmm, well you actually have to TYPE something into it for it to search. Maybe just use some key words instead of a whole sentence.
Well, you've got a cam, header and 2.5" exhaust...just a though...maybe something for the intake? I dunno, I'm spitballing here...How much money do you have? How about a turbo or supercharger???? Look up LCEngineering...
Old Aug 5, 2009 | 09:32 AM
yup didnt type anything in thats why it didnt work. what bout the afm? mine seems to run rich with the mods i have and stock intake.
Old Aug 5, 2009 | 10:24 AM
olharleyman's Avatar
More Power Cheap = No Such Thing
Old Aug 5, 2009 | 12:16 PM
Fink's Avatar
It's the Newbie section guys, lay off of him a little.
Here's a couple I found searching for "22RE power mods."
https://www.yotatech.com/forums/f116...please-185513/
https://www.yotatech.com/forums/f116...s-work-177568/
The bottomline of it is that the 22RE is a 4-cylinder.
It's preferred for its reliability and ruggedness, not for the performance options it has.
Re-gearing is really the only thing that helps regain power but it's very expensive and depending on the tire size you're running it may not be worth it.
Even then, re-gearing doesn't necessarily give you more power just changes your ratios.
I'd say engine swap or put the money into preventative maintenance to keep it running longer.
Fink
Old Aug 5, 2009 | 12:40 PM
BT17R's Avatar
Offhand:
-- Reduce weight with lightest wheel/tire combination, leave the spare and tools home (Fix-A-Flat)
-- Reduce parasitic loss with a flex or electric fan, add +3 psi to tires
-- Use lowest viscosity oil allowed
-- Find a diff from a 1-Ton
Old Aug 5, 2009 | 01:13 PM
thanks fink. im running 5.29's and 39.5 tsls with detroit lockers i running mud only on the road i can do 80mph in 4th and cruise in 5th. in 4 low i can grab 2nd.
Old Aug 5, 2009 | 01:20 PM
Fink's Avatar
Let's back track.
What kind of rig do you have?
Year, make, model, tranny, etc...
Any mods already done?
Sounds like you're off to a good start with the 5.29's...lets take that and run with it.
Fink
Old Aug 5, 2009 | 01:28 PM
1985 toyota pickup sr5 xtracab shortbed 4x4 new 22re from japan engines with 7k w56 5 speed. 7in springs 3in body 2in shackles 39.5 tsls. 88 turbo rear 5.29 gears detroit lockers rear disc conversion ifs front brakes and rotors cross over histeer.
Old Aug 5, 2009 | 04:26 PM
Holy heck, that would have been some useful info at the beginning of all this.
Well, atleast you did the gears!! lol! You could try slapin in a Supra AFM to open your intake up but really theres not much more than what you've already done.
Old Aug 5, 2009 | 09:11 PM
maybe a newbie to the site but this isnt my first rodeo lol i used to have a ported and polished head that really ripped on my 2nd motor but im not up for opening this one up. anyone got a write up for the supra afm setup year make model how to?
Old Aug 5, 2009 | 10:14 PM
BLKNBLU's Avatar
I guess its the "cheap" part of the title that throws some of us. If you're on your 3rd motor, you probably know by now that one thing leads to another. Get a K&N or similar air filter setup and the afm becomes the bottleneck. Get a supra afm and the TB becomes the bottleneck. Get a bored out TB and the intake becomes the bottleneck. Get a ported and polished intake and the head/valves become the bottleneck. Get a performance head w/cam and the exhaust becomes the bottleneck. Get a header and hi flow exhaust and you're done. Wait... with all that air the computer starts dumping in more fuel and the mixture isn't quite right. Now your back to the afm making adjustments. Maybe one of those Jet chip thingies (haven't heard much about them either way)
Sorry. By now I'm sure you've gotten my drift.
cold air intake - don't really know the cost
afm - usually a craigslist find cost negotiable
bored out TB - $300
ported/polished intake - $400
performance head - $500ish
header and exhaust - $300-$1000 depending on how creative/lucky you are
chip - $300 (if they do anything)
End result 125 - 135 hp ----- maybe
It sounds like you've most of the normal stuff already.
If there was a cheap easy fix, we would all be doing it. Best of luck though.
Old Aug 5, 2009 | 10:15 PM
truckman1966's Avatar
Amen brotha
