Sponsored by: CARiD
Traction bar is bent. what to do?
Old Aug 26, 2009 | 05:51 PM
murdarunna19's Avatar
Sorry i mis spoke i meant TRACTION bar, sorry i mixed up my vocab.
Hey yall, the other day i was wheelin and fell into a ditch backwards and my chassis was resting on a big boulder and there was alot of weight on the traction bar. long story short, now my right side traction bar is slighty bent but enough so thats its noticable. how big of a deal is it to replace? and if im replacing is there new ones i can buy that would benefit my truck?
this is on my 2000 4runner.
thanks for lookin guys
-matt
Old Aug 26, 2009 | 07:16 PM
anyone got some advice on how important it would be to fix this?
thanks
-matt
Old Aug 26, 2009 | 07:25 PM
4Crawler's Avatar
Are you talking about the lower control arm on the rear suspension perhaps?
Old Aug 26, 2009 | 07:26 PM
Matt16's Avatar
^I think so, I can't see anything else that would resemble a traction bar (usually a term associated with leaf springs) You should probably eventually replace it, but if it drivers straight enough then its probably not too urgent. The side of the axle on which the "traction bar" (called a lower controls arm or trailing arm) has been bent should be pulled forward a touch. This may or may not be noticeable. It is inducing some stress on the axle housing, but how much would be difficult to tell.
I do believe you can buy stronger lower control arms for this reason... might replace it with this instead of a stock LCA.
Post a pic, that would help.
Old Aug 26, 2009 | 11:47 PM
i will post a pic tomorow once i have my camera.
Old Aug 27, 2009 | 12:11 AM
Elton's Avatar
this part ?
Old Aug 27, 2009 | 10:59 AM
yep^ sorry with all the confusion guys i kinda got it mixed up after not looking at my truck and trying to remember. but yes thats exactly whats bent.
-matt
Old Aug 27, 2009 | 11:00 AM
thanks elton
Old Aug 27, 2009 | 12:02 PM
camo31_10.50's Avatar
now you talkin about the sway bar??..
Or the Trailing arm???(or LCA..whatever..lol...THE BIG BLACK ONE in eltons pics.hahaha)
Old Aug 28, 2009 | 12:22 AM
haha the big black one in eltons pic. is it a priority to replace? or can i get away with replacing it later?
Old Aug 28, 2009 | 08:03 AM
dannomite's Avatar
Just take that thing off. It doesn't do anything anyway. j/k. Depending on how badly it is bent it can pull your axle forward on that side and cause tire wear and alignment issues. That said, depending on how badly it is bent it may not cause a noticeable problem.
Old Aug 28, 2009 | 08:19 AM
i mean it is bent enough to be noticed when u look at it. but it isnt bad enough to really wory me? idk if that makes sense i will do my best to get a pic up today. thanks guys
-matt
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
